Crazy K Posted August 29, 2009 Report Posted August 29, 2009 explain... what exactly is your goal? do you want dark graphite seats instead???? Quote
jake91 Posted August 29, 2009 Author Report Posted August 29, 2009 no i wanted to know if i could dye dark graphite, tan, or red seats white Quote
Addicted To Boost Posted August 29, 2009 Report Posted August 29, 2009 I found a nice set of charcoal buckets in a 96 CS today Quote
xtremerevolution Posted August 31, 2009 Report Posted August 31, 2009 94CutlassVert said: no i wanted to know if i could dye dark graphite, tan, or red seats white You mean bleach. I doubt you could turn a darker seat into a white one. Quote
RZB1992 Posted September 12, 2009 Report Posted September 12, 2009 Just thought I would mention this to you. You can paint a leather or vinyl seat with special paint to the white you want- even if it is a dark seat. We bought a new set of seat covers for my 71 Cutlass- they were dark green and I wanted the pearl white interior... If you go to your local car paint/autobody store, they should have cans of SEM interior paint in aerosal cans- they have them to match GM coloring for interiors. With a few coats of paint, the seats turn out fine, even when you have dark colors (in my experience). The paint also will not wear or flake at all- as long as you clean the seat very well before applying the paint, and if you want, they also sell a special spray to go over the paint to protect it. I also just tried doing this to a set of leather Intrigue seats I had that I was trying to replicate to the 2-tone Final 500 seats. They had a variety of GM colors available, and the paint ended up matching perfectly! It even looks like the seat came that way from the factory- no artificial look. Quote
jake91 Posted September 12, 2009 Author Report Posted September 12, 2009 okay thanks finally nice to here something positive about those paints Quote
RZB1992 Posted September 13, 2009 Report Posted September 13, 2009 Here's some pics of what I used and how the seat came out. Now that the paint's dry, you'll deffinitely want to buy that clear coat spray as well- the leather that got painted doesn't feel as soft or smooth without it. Quote
boulevard Posted September 13, 2009 Report Posted September 13, 2009 Make sure to follow the curing directions as listed by the manufacturer. Something tells me it's gonna fade or peel pretty quick. Good Luck. Quote
Breakdown Posted September 14, 2009 Report Posted September 14, 2009 94CutlassVert said: wtf is cpr? It's important to form a tight seal when you're doing CPR. Quote
jake91 Posted September 14, 2009 Author Report Posted September 14, 2009 my mom almost slapped me when i told her about that. as she is a nurse LOL Quote
Breakdown Posted September 14, 2009 Report Posted September 14, 2009 94CutlassVert said: these are my seat they are beyond any sort of repair i can do Does anyone know why their seats wear there like that I've seen it all over W-body leathers. Personally I've trashed a leather driver's seat, but did not put any wear whatsoever on that portion. Quote
jake91 Posted September 14, 2009 Author Report Posted September 14, 2009 im going to say it is because when you sit down or get out of the car it puts pressure there Quote
Breakdown Posted September 15, 2009 Report Posted September 15, 2009 94CutlassVert said: im going to say it is because when you sit down or get out of the car it puts pressure there I'm going to say that you're doing it all wrong. I've got a decent sized caboose and I've never found a reason to slip in that way. Quote
Crazy K Posted September 15, 2009 Report Posted September 15, 2009 i have rebuilt seats. I will add a sheet of plastic or carpet between the foam and the springs, and if the seat foam is torn i will replace it or glue it together. since the foam and upholstery is the same left and right with buckets. I sometimes completely swap seat upholstery between the seat which really freshens up the seat's appearance by placing the worn areas out of immediate view by the center console, and the unworn areas to the outside... Quote
