veesix Posted September 10, 2003 Report Posted September 10, 2003 I have a 95 Monte Carlo Z34 and the tansmission lost 3rd gear.Now after spending $1700 for a trannie rebuild the car has no lock up. The transmission experts? have had the car for 8 days .the latest news is they have a valve body on order. The torque converter has been changed twice.my question is would a valve body cause this problem? Quote
fleetwoodguy79 Posted September 10, 2003 Report Posted September 10, 2003 Could be, or they could've not hooked up the wiring on the tranny correctly. There is a solinoid on the tranny that makes the tq. converter lock up. Quote
veesix Posted September 10, 2003 Author Report Posted September 10, 2003 I just got back from the trannie shop. they put a valve body for a 96 Monte carlo .They said it now locks up and now the problem is it shifts hard between 1 and 2nd and it sometimes stays in lock up. Is there a difference between the 95 and the 96 4t60-e valve bodies. Quote
PaPaPooh Posted September 11, 2003 Report Posted September 11, 2003 thats funny that the lock up is ecm controled im not an expert by anymeans but i seriously dought the valve body would have anything to do with lock up i also seriously dought they hooked the silonied (sp?) up wrong it is a one way only plug my guess is that they used a shitty reman TC or never changed it and just flushed it what i would do is to ask to see the old TC's if they are not happt to show you they are being "shady" i also would get a different opinion it you get the car back and it does not lock out! most shopes will be happy to do a free dionogstic check for you to take back to the shop you have had it at thats what i would do! let us know how everything is! good luck!! Quote
veesix Posted September 11, 2003 Author Report Posted September 11, 2003 I talked to the mechanic working on the car , i asked to see the scan tool he was using. the ecm was calling for tcc lockup but it is throwing a code 1640 .I've never heard of that?. He also said he changed the lockup solenoid . Thanks for your replies and I will let you know what the the final outcome is . Quote
