thatcutteeboy Posted August 20, 2009 Report Posted August 20, 2009 Hey guys I have a friend that works for a company that might be able to adjust the mileage on our UB3 clusters. I don't want to release the info until I know for sure. I will be sending mine in to them and if it could be done I will keep you all posted. All they say is needed is a notarized document of the mileage that's on your car now or you could send your original cluster in with the UB3. The most important part is that it is really not that expensive. I'll keep you all posted. Quote
89SupremeCutty Posted August 20, 2009 Report Posted August 20, 2009 sounds like a good deal. would they also be able to do this to another electronic cluster from a different vehicle? say from a base impala or monte cluster to a rally cluster? at least i think that's what they're called. Quote
SrMichi Posted August 20, 2009 Report Posted August 20, 2009 Nice i would be very interested in this since i should be getting mt ub3 adapter today and i will be going to junkyard this weekend to get myself a lumina bade cluster to gut. Quote
thatcutteeboy Posted August 20, 2009 Author Report Posted August 20, 2009 sounds like a good deal. would they also be able to do this to another electronic cluster from a different vehicle? say from a base impala or monte cluster to a rally cluster? at least i think that's what they're called. They do work for all GM dealership and Fords Quote
grandprixnyc Posted August 22, 2009 Report Posted August 22, 2009 I'd love to have the digital cluster in my GP adjusted... Quote
pitzel Posted September 3, 2009 Report Posted September 3, 2009 I've been able to adjust the UB3 clusters *forward* by applying a sine wave, from a signal generator, or a computer sound card (with a booster amp). Â But if this outfit can adjust them in *reverse*, please, post the source. Quote
SrMichi Posted September 3, 2009 Report Posted September 3, 2009 can't you just keep going foward till it goes back to 0 Quote
Crazy K Posted September 3, 2009 Report Posted September 3, 2009 can't you just keep going foward till it goes back to 0 no. it locks at the maximum amount it can show. someone did tried and locked the one they were trying at the maximum amount. probably 262164 miles. there exists a thread if anyone can find it. Â but... if you could isolate the chip that the mileage info is on... a new chip to replace it would probably start you out at zero! Quote
Stevo Posted September 4, 2009 Report Posted September 4, 2009 There's a guy on Ebay that can set the digital clusters to whatever mileage is needed. I think he mostly works on the 1st gen of w digital clusters that had the error message after 199999 km's or miles. He has a small stock of them and you send him yours and he sends you one of his repaired modules. Quote
Addicted To Boost Posted September 4, 2009 Report Posted September 4, 2009 There's a guy on Ebay that can set the digital clusters to whatever mileage is needed. I think he mostly works on the 1st gen of w digital clusters that had the error message after 199999 km's or miles. He has a small stock of them and you send him yours and he sends you one of his repaired modules. I think that was the 1st gen Cutlass clusters only that did that. The digital cluster on my 89 GP showed 224,000 miles and still worked perfectly. Quote
Crazy K Posted September 4, 2009 Report Posted September 4, 2009 There's a guy on Ebay that can set the digital clusters to whatever mileage is needed. I think he mostly works on the 1st gen of w digital clusters that had the error message after 199999 km's or miles. He has a small stock of them and you send him yours and he sends you one of his repaired modules. I think that was the 1st gen Cutlass clusters only that did that. The digital cluster on my 89 GP showed 224,000 miles and still worked perfectly. REGALs are the ones that did that. Quote
Regal_GS_1989 Posted September 4, 2009 Report Posted September 4, 2009 Regals werent the ones that did that. The ones that i've seen all the time have been the base cutlass digital dashes. The Base regal digital dashes have a regular (IE. Non-Digital) odometer, and the UB3 ones generally roll over without issue. I've got 2 of them here with over 300 000 km on each. They've rolled over 199999 obviously. Quote
Crazy K Posted September 4, 2009 Report Posted September 4, 2009 Regals werent the ones that did that. The ones that i've seen all the time have been the base cutlass digital dashes. The Base regal digital dashes have a regular (IE. Non-Digital) odometer, and the UB3 ones generally roll over without issue. I've got 2 of them here with over 300 000 km on each. They've rolled over 199999 obviously. it is supposed to be at 200,000 miles where they fail... Quote
Regal_GS_1989 Posted September 4, 2009 Report Posted September 4, 2009 Regals werent the ones that did that. The ones that i've seen all the time have been the base cutlass digital dashes. The Base regal digital dashes have a regular (IE. Non-Digital) odometer, and the UB3 ones generally roll over without issue. I've got 2 of them here with over 300 000 km on each. They've rolled over 199999 obviously. it is supposed to be at 200,000 miles where they fail... Well...I have a cluster with 240 000ish miles on it and it never failed. All that happens is a little rectangle next to the word miles lights up to indicate that mileage displayed is not actual. I have only ever come across one of the UB3 clusters that showed error, and it also had several several segments of the digits burned out... so I can only assume that there was other items that were fucked. Quote
Stevo Posted September 6, 2009 Report Posted September 6, 2009 The designed the first digit to read 1 because that digit wont read an 8 it reads error instead. Quote
