rockfangd Posted August 16, 2009 Report Posted August 16, 2009 Hi all. I am trying to work out a few bugs on my new W-body lol so dont mind all of the threads. Ok so The ABS light is constantly on on my 2000 lumina. I pulled the code and this is what i have. 1262 RF motor circuit short to ground. I have never seen this code before so i have no idea what i am looking at, whether it be a speed sensor or the whole unit. I am confused on this and i would like to fix the problem, not bypass the ABS feature. Thanks for any info in advance Quote
89SupremeCutty Posted August 16, 2009 Report Posted August 16, 2009 probly a bad sensor on the right front wheel. Quote
rockfangd Posted August 25, 2009 Author Report Posted August 25, 2009 bump on this. Could it be just the sensor? Also mods feel free to move this to the proper section if you feel it is posted in the wrong section Quote
89SupremeCutty Posted August 26, 2009 Report Posted August 26, 2009 try replacing the wheel sensor. Quote
Go4DaMo Posted August 26, 2009 Report Posted August 26, 2009 My 1993, along with my dad's do the same thing. I checked the fuses and blew out the rear sensors when I put struts on, but to no avail. I can't run a specific code with it being a pre-1996 model. I want to fix mine as well. It started doing this over the summer and I've locked up my tires 4 times since then. NEED ABS! Quote
White93z34 Posted August 26, 2009 Report Posted August 26, 2009 When I get home tonight I'll break out a service manual, and see if it lists the specifics of that code. Quote
rockfangd Posted August 26, 2009 Author Report Posted August 26, 2009 When I get home tonight I'll break out a service manual, and see if it lists the specifics of that code. Thank you very much. I dont think it is just the rf sensor Quote
White93z34 Posted August 26, 2009 Report Posted August 26, 2009 I don't have a 2000 lumina manual, but beings that it is OBD2, and ABS IV the 98' regal manual should provide the same codes and descriptions. Quote
digitaloutsider Posted August 27, 2009 Report Posted August 27, 2009 ABS "motor" errors pertain to the ABS unit itself, not the WSS. Quote
1990lumina Posted August 27, 2009 Report Posted August 27, 2009 The ABS unit is probably fucked guys. Lets not beat around the bush here. Quote
rockfangd Posted August 27, 2009 Author Report Posted August 27, 2009 thats what i am thinking. I just wanted to find out more and see if it can be fixed Quote
