Garrett Powered Posted August 15, 2009 Report Posted August 15, 2009 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=120402451291&viewitem= is this better than our stock downpipe flange? Quote
GutlessSupreme Posted August 15, 2009 Report Posted August 15, 2009 I don't think it'll work. Or it'll be close. The bolt pattern looks and should be the same, but where the two bolts are that are closest together, below the wastegate - our turbine housing is shaped differently. It doesn't bow-inwards in that semicircle shape between the bolts, it runs straight between them. I dunno if his flange will seal in that area. ours: http://www.gtsdurango.net/images/cars/IMG_6861b.jpg http://www.gtsdurango.net/images/cars/IMG_8366b.jpg Quote
Crazy K Posted August 15, 2009 Report Posted August 15, 2009 i'd think not... it kind of restricts flow... but then again... if the turbo is jetting a straight thru blast..... Quote
Garrett Powered Posted August 15, 2009 Author Report Posted August 15, 2009 this is the stock one next to the gt2871r that people have been bolting up to our flange. I never noticed that difference in the shape though, hmmm. I might consider building a complete downpipe if I wanted a good seal on my ball bearing turbo anyway. I will probably build two downpipes now actually. one for my ball bearing one and one for journal bearing style with the modified stock flange. Quote
desert sling Posted August 24, 2009 Report Posted August 24, 2009 i purchase ss gaskets from ebay the downpipe did not seal above the wastegate Quote
Garrett Powered Posted August 24, 2009 Author Report Posted August 24, 2009 I bought the flange last night. should be here soon. Quote
GhrarhG Posted August 25, 2009 Report Posted August 25, 2009 I bought a T25/28 flange that had both bolt patterns in it did not seal at the side. I had to fill it with weld and file flat to cover, then grind out the inside for flow. It did bolt up correctly, but the shape did not match our turbo. Good luck with yours. Quote
