digitaloutsider Posted August 11, 2009 Report Posted August 11, 2009 I'm going to get a 1G DSM BOV installed on the TGP soon, and I just had a quick question.. where you are guys tapping into the vacuum source for it? I'm guessing there's some universally accepted line that everyone uses. I can't find ANYTHING on the TGPForums as everything is 7 years old the links are dead. Quote
digitaloutsider Posted August 11, 2009 Author Report Posted August 11, 2009 Nevermind. Found my answer. Anything engine side of the TB should work. Quote
Addicted2bass Posted August 11, 2009 Report Posted August 11, 2009 You can use the vacuum coming off the back of the engine that would be for the master cylinder on non turboed 3.1s. On our cars there is a bolt back there blocking it off. I have the parts to do this but havent done it yet. Right now my BOV and boost gauge are running off of the TB, but using the vacuum on the back of the engine is a much better/cleaner way of doing it. Matt has it set up that way on his car so you could ask him for more details. Quote
Addicted To Boost Posted August 12, 2009 Report Posted August 12, 2009 I just spliced in a rubber T near my cruise control on the main vacuum line and ran it from there. Quote
GOT2B GM Posted August 12, 2009 Report Posted August 12, 2009 Matt has it set up that way on his car so you could ask him for more details. Quote
PhatMpk Posted September 13, 2009 Report Posted September 13, 2009 How did you set your up from the TB as my line in the back is already being used for my non-abs master cylinder to power my brake booster? Quote
Addicted2bass Posted September 14, 2009 Report Posted September 14, 2009 You should be able to use any of the lines off the TB and use a T connector. I have my BOV and boost gauge running off the cruise line since the cruise is no longer in the car. Im gonna redo it when i put the cruise back in. Quote
