Dirty Rockstar Posted August 5, 2009 Report Posted August 5, 2009 Hey gang. I did a search and found that the 114.3mm bolt pattern will fit our cars. I may have an opportunity to pick up a sweet set of 17" rims with tires. I would ideally like these to go on the Lumina when it lookin better because I don't think the style would match the Intrigue well. They are currently on a 99 or so Mitsubishi Eclipse. I am just wondering if they will fit without much issue on either of my cars. I just want some rims, and all I would need to do to get these is buy some stock Mitsubishi rims and make a swap. I guess what I need to know are things like offsets and whatnot. I am nowhere near an expert nor will I pretend to be. Thanks gang! Quote
jeremy Posted August 6, 2009 Report Posted August 6, 2009 the bolt pattern would work, offset and tire size would still need to be known to determine if the setup would work though Quote
