a howling noise
stlunatics2oo3
my car is making a howling noise seems to be coming from under neath plenum what might it be?
describe this howling noise a little...does it change with the engine's RPM's? Does the car run crappy? It's possibly a vacuum hose cracked or leaking...
yeah it is reving like crappy and is like dyin down and stuff so how do i take the plenum off
well, since the last thing you did was take off the throttle body to fix the oil pump drive, first thing to check is that the black rubber vacuum harness on top of your throttle body is properly installed and seated. Then make sure the intake pipe/hose is tight and on the TB correctly. Let me know
