crazyd Posted July 22, 2009 Report Posted July 22, 2009 I've got the 12-pin connector on my '94 and an SES light I'd like to figure out. I've got pin A but no pin B like I expected to find to jumper them together. Tried putting a code scanner on it at Schuck's but it says no response from PCM. How do I pull codes out of this crazy car? Quote
Crazy K Posted July 22, 2009 Report Posted July 22, 2009 no such luck. 94-95 obd 1.5 cars require a scanner to check the codes, and it is a scanner that is very hard to find. Do you have any idea what might be causing it? try to state the conditions in which is occurs. always on? only on once the engine is warm? only on once the engine is warm and you are coasting? Quote
mfewtrail Posted July 22, 2009 Report Posted July 22, 2009 Scanners for them aren't hard at all to find. Autoxray scan tools that will read OBD-I are always on ebay. The OBD-I only scantool is the autoxray 3000. You can often buy them for right at $100 shipped and they'll scan quite a few older cars. I have an AX' 3000 that I use at home on a regular basis and I've scanned several '94-95 w-bodies with it. http://cgi.ebay.com/USED-AUTOXRAY-EZ-SCAN-3000-OBD-CODE-SCANNER_W0QQitemZ250464051109QQcmdZViewItemQQptZMotors_Automotive_Tools?hash=item3a50d21fa5&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1205%7C293%3A1%7C294%3A50 There are 7 of those on ebay currently from what looks to be the same seller... EDIT: There are other scan tools out there, just do a bit of searching and you'll find them. Quote
crazyd Posted July 22, 2009 Author Report Posted July 22, 2009 Ok, the light is intermittent. It is off at startup, then comes on once the car warms up (after 2-3 mins). It stays on until I shut off the car, but I just noticed today that it had turned off and come back on after I had stomped on it for an onramp. Based on that my instincts tell me it's probably either an O2 or EGR problem. I just finished a block-up head gasket rebuild with replacement heads, both f/r. The engine was filled with about 5 gallons of chocolate slushie from the pan to the intake snorkel and everywhere in between. The SES light appeared about 30 miles after the rebuild was completed. Quote
19Cutlass94 Posted July 23, 2009 Report Posted July 23, 2009 more than likely its an O2 problem. EGR really isnt used all the time. Quote
slick Posted July 23, 2009 Report Posted July 23, 2009 You would most likely get your EGR code after you drove the car, then came to slow down. Quote
crazyd Posted July 29, 2009 Author Report Posted July 29, 2009 I decided to try calling my local dealer to see how much he'd charge to scan the codes out. "Just to read the codes? You don't want any diagnostics or repair? No charge." Never did find out what it was, I sold the car and the buyer said he didn't care about it since it passed emissions inspection. Really, really well. As in, 1/15th of its previous test scores on HC, and a big 0.00 score on CO. With the SES light still on in the test station! Quote
Crazy K Posted July 29, 2009 Report Posted July 29, 2009 I decided to try calling my local dealer to see how much he'd charge to scan the codes out. "Just to read the codes? You don't want any diagnostics or repair? No charge." Never did find out what it was, I sold the car and the buyer said he didn't care about it since it passed emissions inspection. Really, really well. As in, 1/15th of its previous test scores on HC, and a big 0.00 score on CO. With the SES light still on in the test station! that's nuts! i had the O2 go bad on a 94 with a 3100. once the engine was going and the code triggered, the engien tone was different. I would describe it as a feeling that the engine was pulling timing and the noise of the engine was a bit more of a roar at a cruising speed of 60mph cranking 2000 RPM. Then again maybe it was just a pig rich mixture being delivered... my fuel economy dropped from about 29mpg to 21mpg for that tank.... Quote
Elias1552 Posted September 25, 2013 Report Posted September 25, 2013 does any other obd1 scan tool work on a 94 3100 montecarlo? Quote
l67ss Posted September 25, 2013 Report Posted September 25, 2013 94 monte carlo? does any other obd1 scan tool work on a 94 3100 montecarlo? Quote
Psych0matt Posted September 25, 2013 Report Posted September 25, 2013 94 montecarlo? That doesn't exist... Quote
l67ss Posted September 25, 2013 Report Posted September 25, 2013 Wut i thot That doesn't exist... Quote
RobertISaar Posted September 26, 2013 Report Posted September 26, 2013 in any case, an ALDL cable will work just fine for this type of situation. Quote
Schurkey Posted September 26, 2013 Report Posted September 26, 2013 Any "scan tool" that WON'T read a '94 W-body must be a consumer-grade piece of junk. Quote
19Cutlass94 Posted September 27, 2013 Report Posted September 27, 2013 Any "scan tool" that WON'T read a '94 W-body must be a consumer-grade piece of junk. x2. Although we refer to '94 as OBD 1.5, its still an OBD1 car. Any OBD1 code scanner should be able to read it. Quote
Elias1552 Posted December 10, 2013 Report Posted December 10, 2013 Would any scan tool for obd-1 read transmission codes? Or do I need to buy a newer one that can also read obd-1? Sent from my iPhone using Tapatalk Quote
Elias1552 Posted December 10, 2013 Report Posted December 10, 2013 Sorry it's a 95 ls. Sent from my iPhone using Tapatalk Quote
Elias1552 Posted December 11, 2013 Report Posted December 11, 2013 Sorry it's an error. I meant to type 95. Sent from my iPhone using Tapatalk Quote
Elias1552 Posted December 11, 2013 Report Posted December 11, 2013 sorry, I meant 95. I was on the phone . Quote
Schurkey Posted December 11, 2013 Report Posted December 11, 2013 sorry, I meant 95. I was on the phone . Any "scan tool" that WON'T read a '94 W-body must be a consumer-grade piece of junk. Ok, any "scan tool" that won't read a '95 W-body must be a consumer-grade piece of junk. Quote
Elias1552 Posted December 13, 2013 Report Posted December 13, 2013 I bought a actron code scanner for gm and Saturn that's suppose to make the light flash but nothing. Quote
Galaxie500XL Posted December 13, 2013 Report Posted December 13, 2013 What scanner did you get, and what light are you trying to get to flash? Quote
RobertISaar Posted December 13, 2013 Report Posted December 13, 2013 that would be why. tools that flash codes over the SES light are nothing more than a direct link from pin A to B. you could recreate it using a paperclip or a thousand other metal devices that cost a penny each. the 93-95 3100 code does not support flashing codes out over the SES light. NEEDS to be via ALDL communication. Quote
Galaxie500XL Posted December 13, 2013 Report Posted December 13, 2013 (edited) I've gotten the SES light as you describe for two reasons...O2 sensor bad, and evaporative purge solenoid bad. But, as Robert says, the only way you'll really know is with a scantool that communicates with the ALDL connector. BTW, if you find one, the evaporative purge solenoid failure shows up as a "QUAD A" failure...it never specifically tells you what device actually failed. The scantool I use I bought several years ago, it's an ancient Actron CP9110. It WILL read codes, and MOST live data on my '95 LQ1..not everything, but almost everything. There's one on eBay right now for $89.00, which is quite a bit more than I paid for mine. The one listed right now has a Chrysler cartridge and cable, you'd also need to buy the GM cartridge, and cable. I lucked up, and mine came with the GM cartridge and cable, I paid $50.00. Later, I bought the Chrysler cartridge and cable, I think I paid $30.00, for use with my '94 LeBaron convertible. Edited December 13, 2013 by Galaxie500XL Quote
Galaxie500XL Posted December 13, 2013 Report Posted December 13, 2013 BTW, they're also handy to have when buying older cars...I put the fear of God in the used car salesman when I bought my Cutlass...he downplayed the significance of the CEL that was lit, and I asked him if he minded if I got my scantool out of the trunk, and checked out WHY the light was on. 3 error codes read later, his eyes were wide, and he began dropping the asking price on the car. Quote
