Bryan921SS Posted July 18, 2009 Report Posted July 18, 2009 1996 Cutlass Supreme 2 Door 3100 V6....been having a Cyl 6 misfire code on and off for the past 4 months. Changed all 6 plugs and put new wires on. The problem went away for over a month, now today it is back. The car started really ruff twice...but then evened out and drove like it always does. Could it be a coil? Car is hot right now so once she cools down I am pulling the #6 plug to see if it is fouled. Any ideas?? Quote
Crazy K Posted July 18, 2009 Report Posted July 18, 2009 what plugs did you put in? could be also be an injection or compression issue, as I understand from teh OBD II system. btw, you could swap two of the coils very easily on that motor to rule out the coils. Quote
Bryan921SS Posted July 18, 2009 Author Report Posted July 18, 2009 AC Delco plugs, pre-gaped but I checked them anyway. I haven't had a compression test done yet, but I throw fuel injector cleaner in there every time the oil is changed...so I wonder if the injector is dying. I just did the LIM and UIM job a few months ago and it passed a pressure test. Should I get a compression test done on it, or would that be a waste? Quote
Crazy K Posted July 18, 2009 Report Posted July 18, 2009 check the plug's condition do a spark check to see if the wire on six is as strong as any of the other wires. try the coil swap? ohm the injector Quote
Bryan921SS Posted July 18, 2009 Author Report Posted July 18, 2009 Thanks I will start with the plug...I don't have to right tools to check the ohm's but I will check the plug and the plug wire. /***EDIT***/ One half of the plug is fouled with black soot and extends down the side of the plug 4-5 threads. The other half is nice and clean, I listened to the injectors and I think the number 6 one isn't making the same sound as the other two front injectors. Quote
douellette Posted July 19, 2009 Report Posted July 19, 2009 mines having the same problem, basically the same car just its a 1997 and cylinder 1..which is like the hardest one to get to because its in the back. Quote
tunerlover3 Posted July 19, 2009 Report Posted July 19, 2009 Then look up the ohm specs from a manual and ohm out the injector. If it doesnt sound right, most likely is not firing right. Quote
