GnatGoSplat Posted October 21, 2002 Report Posted October 21, 2002 CODE 44 Trouble Code 44 indicates that the O2 sensor is showing a persistently high exhaust oxygen content (lean), despite the efforts of the ECM to increase injector on-time (thus increasing fuel delivered). Integrator and BLM numbers may indicate > 128 by a substantial margin. Code 44 is set when: O2 sensor voltage remains below .2 volt for 60 or more seconds System is operating in "Closed Loop." No Code 33 or Code 34 Possible causes include: O2 sensor defective or lead shorted Lean injectors (dirty or blocked) Water in fuel Exhaust leaks upstream of O2 sensor Fuel pressure too low Note: Presence of Code(s) 33 and/or 34 may indicate MAP problem. This should be the first suspect in the case of a Code 44 being set. Quote
