Losing oil
supreme_style21
'02 GP - 3800 NA engine - 60,000 miles
I'm due for an oil change this week.. I'll admit I check the oil only monthly. I put on about 2k a month. Low oil light came on yesterday after work. I was about 2 quarts low :eek:
No spots on the garage floor. Valve covers don't seem to be leaking. Filter, drain plug and oil pan gasket shows no sign of leaking. A 60k engine shouldn't be BURNING oil? I run synthetic blend. What am I missing??
My Regal uses a bit of oil between changes too. Mine will generally go down about 1/4 to 1/2 a liter on a ~3500 mile change interval. I have been told that a good engine will burn a little bit of oil between changes.
I also have about the same mileage as you too.
I just checked my oil and it is about 1/4 below the full mark. I am also slightly over my mileage for my oil change.
my kids mom had a 96 l36 and it used oil too. the low oil light came on once. it never smoked either.
its shouldnt be normal. is your back bumper black?
Bad PCV valve?
Didn't think of that .. Probably has never been changed. I'll pick one up tomorrow!
