Hornet 554T Wiring. HELP!!!
MommyTaz022200
I have the wiring for most of the alarm hooked up, but the install direction book is about the worse writen book I have ever seen. So here's the wires and discriptions that I can't figure out:
Starter kill relay wires:
The green and black ones go to the starter, and I got those figured out. There is a yellow wire from the relay and the book just shows it goes to the ignition on a different wire then the one for the starter. I don't know which wire it goes to because they do not show what the wire from the ignition connects to. There is only a diagram, no description.
Relay Satelight Key Switch (Remote Start):
Pink wire on alarm: "(+) ignition Output- Connect this wire to the ignition wire in the vehicle." WHICH ONE?
Purple wire on alarm: "(+) Starter Output- Connect this wire to the starter wire in the vehicle." (The yellow wire from the ignition to the starter? I'm not sure if that's an output)
Link to comment
Share on other sites
