96 BUICK REGAL TEMPERATURE SENDER SPECS
I would like to test the 3 wire temperature sender under the thermostat housing. If I unplug the cable both fans fans run, and the temperature gauge drops to cold. I see aprox 600 ohms yellow to black wires and infinitty black to green..THE GAUGE appears to be working normally. THANKS
This is the info I have for my 1996 Firebird. Should be typical to most GM cars.
*F Ohms
212 177
194 241
176 332
158 467
140 667
122 973
113 1188
104 1459
95 1802
86 2238
77 2796
68 3520
59 4450
50 5670
41 7280
32 9420
23 12300
14 16180
5 21450
-4 28680
-22 52700
-40 100700
BTW, has your gas mileage been crappy or normal?
Gas mileage has been fine...I will try putting a resistor aprox 150 ohms to see if the fans come on.The yellow and blk leads appear to be the one's that go to the ecm to control the fans..Thank you for the infoo.
If gas mileage has been fine, then the coolant temperature sensor is probably fine as well.
