Hello
I finish swap my CSC manual .. but now I have a little problem and I can'T find it's what...
My car start perfectly, and run good at Idle (900-1000RPM) my problem is here .. When I put in first gear. it's ok until 5000RPM .. after the engine not run good ... RPM dance between 2000 and 5000 RPM... and the SES light flash.. in second gear it's same thing but at 3000rpm .. third gear at 2500 etc ... and .. when my engine run on Idle.. when I turn the wheel .. my engine want stall .....
please .. help me :(
may-be the EGR valve ?? or PCV valve ?? :S
I have a new sparkplug, new MSD wires, I take the original coilpack, but move to the top, Vacuum problem ??
Thanks !
Yann
it will be very hard to tell. do a spark test at least.
I do a simple phillips screwdriver in the end of each plug wire. if you have an extra/old wire you can use this instead of pulling every plug off the plug. basically spark check all 6 coil contacts for a healthy blue spark.
also, could it be a bad TPS?
it's possible it's a vaccum problem ?? one hose not plogued or 'squeze'
I had check .. all it's connected ....
It sounds to me like a computer/VSS/auto problem. I know you swapped in the manual.... what computer/chip are you running?
I had keep the same computer (CSC automatic 1994)
but I had make the same thing of my GTP .. on my GTP no problem, same connection in same place ( I keep the GTP wirring... to keep the same method)
WELLL WELLL WELLLL ! lol
I have find the ... probleme ...
Each time I would work on my cutlass ... I had boosted my car ... went the car run.. on idle .. the alternator have a lot of 'juice' to run the car .. but went I REV my engine .. at 5000RPM my alternator had not enough power for the coilpack because my batery was scrap .. no charge on it....
I have change the batery and ALLL it's OK!!
big crapp lol
Now .. I have a Cutlass Supreme Convertible Manual !!!! :D
Glad you found it and it was something simple! You've got one sweet ride there!
