how hard would it be to swap a 3.8L supercharged engine into a 97 cutlass supreme?
use the search function. theres a few poeple here i think that swapped out a 3100 for an l67.
Not near as hard as you would think. Let me know if I can help.
that came out nice, i was thinkin about doing the series 1 engine but the 220-225hp version of it. what can i find that in? and do i have to do any modifications to the motor mounts or any welding?
I did have to "trim" the firewall (about a 4x6 inch spot) to clear the exhaust downpipe.
Everything else was bolt in. I used a 00 GTP drivetrain. I modified the axles to fit the
Cutlass and used a 99 Lumina 3800 harness which I had to move a few wires around
at the bulkhead connector to mate it to the Cutlass. I would do a series II. Your car already
has the OBD II diagnostic connector which makes it a little easier to wire up and ease of
plugging a scan tool in to check codes, etc.
why would swap in a series I ?
he was probably misinformed in that it would be easier to do a S1... i've seen that argument before..
yeah i read somewhere that it was quite a bit easier to swap in a s1 instead of a s2. is it actually worth using a s2 over an s1?
very much so... not only is every S1 getting close to ridiculous mileage and needing rebuilds, S2 had better EVERYTHING: fuel economy/power/emissions/weight/reliablity.
now coming from someone who HATES 3.8 motors, the S2 is a giant leap forward compared to a S1...
now the only problem is....who's got $300 they want to spare? lol
