outatime Posted June 28, 2009 Report Posted June 28, 2009 On my 96 regal I vacummed the system down and hooked up the freon can and it won't take a charge. The compressor is coming on when I turn it on so I know it's working. I was thinking maybe it's blocked. Maybe it's the expansion valve is blocked ? Quote
89SupremeCutty Posted June 28, 2009 Report Posted June 28, 2009 if you vacuumed the system, then the compressor shouldn't be coming on when you turn it on cause there's no freon. the only way for it to turn on with no freon in the system is to jump the compressor relay under the hood. i would get a pressure gauge and hook it up to the low side and see what the pressure is at. Quote
jerry455 Posted June 28, 2009 Report Posted June 28, 2009 check orifice tube, but if it is getting plugged what is causing it? compressor maybe going. Quote
mfewtrail Posted June 29, 2009 Report Posted June 29, 2009 What type of setup are you using to charge with? I would make sure that the valve(s) you're using on the can tap and manifold gauges(assuming that's what you're using) are actually opening and allowing refrigerant to at least flow through them. For what it's worth, I've never had to manually jump a compressor to get a bone dry system to accept a charge. After so much of the first can(using 12oz cans) goes in, the compressor will kick on and quickly empty the can. Submerging the cans in warm(not hot) water will help speed up the transfer of the refrigerant by increasing the pressure of the can. Less refrigerant will be retained in the can when heating it with warm water also. Quote
outatime Posted July 1, 2009 Author Report Posted July 1, 2009 I did get it to take the freon finally. Three cans actually. But it's still not blowing cold so I think it's the expansion valve. I'm going to replace it today and see what happens. Quote
89SupremeCutty Posted July 1, 2009 Report Posted July 1, 2009 what did you do to get it to take the freon? Quote
outatime Posted July 1, 2009 Author Report Posted July 1, 2009 what did you do to get it to take the freon? It was just going really slow at first. I'm used to cans getting really cold really fast. Per chance do you know where the expansion valve is ? Quote
89SupremeCutty Posted July 1, 2009 Report Posted July 1, 2009 it's below the master cylinder. there's a joint in the a/c line and it goes in there. Quote
outatime Posted July 1, 2009 Author Report Posted July 1, 2009 it's below the master cylinder. there's a joint in the a/c line and it goes in there. Thanks ! Quote
