Oxygen Sensor Part #s, quick reference INTERCHANGE
OXYGEN SENSORS; ACDELCO part numbers: (if more than one is listed, both will fit)
notes: all OBD 1 cars checked use the same sensor.
notes: all OBD 1.5 and obd 2 cars checked use 4 wire oxygen sensor.
notes: all 4 wire sensors have the same interchangeable generic sensor, meaning the difference in the part numbers is primarily the plug!
2.3 (140cid) displacement:
VIN A 1990 CS 2.3 HO Quad 4
AFS21 TYPE #21 female 1 wire connector {replaces 213-503 #19211437, 25166816}
AFS81 TYPE #21 female 1 wire connector {#19211437, 25162600, 25166816, AFS21}
VIN D 1990-1991 2.3 LO Quad 4
2.8 (173cid) displacement:
VIN W 1988-1989 2.8 MPFI V6
3.1 (189cid) displacement:
VIN V 1989-1990 TGP/TSTE 3.1 MPFI TURBO V6
VIN T 1989-1993 3.1 MPFI V6
VIN M 1993-1995 3100 SFI V6
AFS75 female 4x1 wire connector {#19178930, 213509, 25171579, 25312184}
VIN M 1996 3100 SFI V6
AFS75 female 4x1 wire connector {PRE-CONVERTER} {#19178930, 213509, 25171579, 25312184}
AFS97 male 2x2 wire connector {POST-CONVERTER} {#19178921, 25312196}
AFS123 male 2x2 wire connector {POST-CONVERTER} {#12587214, 19178924, 25312207, AFS116}
VIN M 1997-1998 3100 SFI V6
AFS109 female 2x2 wire connector {PRE-CONVERTER} {#19178958, 25312203}SENSOR,HTD OXY(POSN 1) IN EXH MANIFOLD/CROSSOVER
VIN M 1999-2001 3100 SFI V6
AFS141 male 2x2 wire connector {#19178747, 25318321}
3.4 (207cid) displacement:
VIN X 1991-1993 3.4 MPFI TWIN CAM/DOHC v6
VIN X 1994-1995 3.4 SFI DOHC V6
VIN X 1996 3.4 SFI DOHC V6
VIN X 1997 3.4 SFI DOHC V6
3.8 (231cid) displacement:
VIN K 1998 3.8 SFI V6
VIN K 1999 3.8 SFI V6
INCOMPLETE. MANY MORE TO LIST... MORE TO COME!
WANT TO HELP? HAVE MORE INFO? add it and it will be incorporated.
WHEN THIS THREAD IS DONE, IT WILL BE MOVED AND POSTED TO FAQ
