Some may know I am doing a rear coil over with some 2nd gen parts.
I have finally been able to prove that the 2ng gen lats and spindle rods are NOT 1 inch longer.
They are 1/2 inch on center.
I have pictures that I will need to load so that you can see.
To prove this I took the one and put a bolt through the stock unit and the 2nd gen.
Then laid them down.
I show that it is a little less than 1/2 inch. This is for both the lateral and the spindle.
Noted: the lateral and spindle rods are different lenght.
good to know.
QUESTION: can the slightly longer second gen lateral links be used with the first gen leaf spring? or must you go with coilovers?
hum, no one has done it that I know of. Makes sence that it would require the coil over.
I dont get it, mine are longer..
Damn, wonder if I grabbed mine from a 04 Impala and not an 03... Would make sense as I was told that 04+ Ws have longer lateral links..
And WTF is a spindle rod??
We have 2 lateral links and 1 trailing arm..
Ima gonna have to investigate this next time im at the JY, I will just rip sets off..
I measured appx 3/4-1" difference on both lateral links from my 96CS to the Gen2's I grabbed..
Spindle Rod is the front rod
The rear is lateral.
This is GM's terminology in the 97-03 W-Body.
Ahh, well GM called them front or rear lateral links prior to Gen 2s :lol:
  • 2 months later...
I have taken pictures that I will post in the next few days that show that the 2nd gen lateral arms are about 3/8 -1/2 inch longer than stock lateral arms.
Lateral links - Go from center of car to spindle (4)
Trailing arms - Go from rocker to the spindle (2)
Just thought i would clear that up :lol:
Ken, I think if you went with longer lateral links you would have to either do a coil over conversion, or find a leaf spring company that can make you one long enough to make up the difference.
Jamie
