boymeetspavement Posted June 21, 2009 Report Posted June 21, 2009 From 1st to 2nd this thing is shifting super hard, I mean the only harder shift Ive seen was on a worked 5.0 mustang. It just started randomly doing this, there are no weird noises nor is there an issue with any of the other shifts..just 1st to 2nd..should I be concerned? Im happy with the feel of it, Im just wondering if its bad for the tranny or if somethings gonna go. Quote
boymeetspavement Posted June 21, 2009 Author Report Posted June 21, 2009 92 gp se sedan uhh not sure of the trans..havent looked into it yet..Im guessing its the 4t60? Quote
Crazy K Posted June 21, 2009 Report Posted June 21, 2009 does it have overdrive? = P R N OD D 2 1 (OD iswritten as a circle around the first D) or 3 speed auto = P R N D 2 1 Quote
boymeetspavement Posted June 21, 2009 Author Report Posted June 21, 2009 yea its a 4 speed, I know that much. lol I had a 3t40 in my cutlass ciera and that thing was bullet proof, I hope to god this 4 speed is as tough. Quote
Masterchief362 Posted June 21, 2009 Report Posted June 21, 2009 My Cutlass did this (95 CSS 4t60-e)... first hard shifts, then slipping and hard mixed... then after a couple months of me neglecting it, tranny broke, and I spent $1200 to have it fixed. Of course, it is now working like a dream. So be careful... have a tranny place check it out for you. Quote
Crazy K Posted June 21, 2009 Report Posted June 21, 2009 I will say that it might be a bad transmission modulator, or worse. do you know what that is? Quote
cubsfan24 Posted June 21, 2009 Report Posted June 21, 2009 Define crazy hard. My 96 Lumina shifts fine 85% of the time but when the fluid gets nice and hot the 1>2 shift gets kinda clunky. It has gotten better since I changed the filter and replace half the fluid. Its been doing it ever since I got the car and that was 15k ago. Even when the tranny fluid is hot it will only shift kinda clunky/hard if you accelerate mildly. I also read on here that a noticeable 1>2 shift is common/normal for these trans. Quote
jake91 Posted June 21, 2009 Report Posted June 21, 2009 i love the 1>2 shift in my car, and i have once or twice manually shifted it, and when you do that it bites second and takes off. its fun LOL. but back on topic sorry. Quote
w-bodys_are_the_best Posted June 21, 2009 Report Posted June 21, 2009 My 94 Cutlass did this about a week after a fluid/filter swap and flush, it hit once or twice so hard it chirped the tires, another week went by and the thing grenaded itself. Quote
boymeetspavement Posted June 21, 2009 Author Report Posted June 21, 2009 lol man dont tell me that. I spoke with a mechanic and he suggested trying an additive and going from there. He also warned me that a fluid change could do more harm than good. Quote
Crazy K Posted June 21, 2009 Report Posted June 21, 2009 don't flush, but you could do a pan drop only and see what happens. Quote
BXX Posted June 21, 2009 Report Posted June 21, 2009 don't flush, but you could do a pan drop only and see what happens. Why?? You have no real proof not to do a flush... I do them all the damn time on all kinds of vehicles including high mileage and burnt fluid... If you flush the car and it granades shortly after, it was gonna granade soon anyway... A flush WILL NOT and CAN NOT damage a good transmission... Im fuckin sick of hearing 'dont flush it, the trans will just fail' from people with NO real experience Quote
BXX Posted June 21, 2009 Report Posted June 21, 2009 pressure control solenoid doesnt have one.. He just prolly needs a new vacuum modulator... It controls how hard it shifts... Quote
GP1138 Posted June 21, 2009 Report Posted June 21, 2009 I will say that it might be a bad transmission modulator, or worse. x2... check the vacuum lines going to the modulator, they dry out and crack often. Quote
BXX Posted June 21, 2009 Report Posted June 21, 2009 I will say that it might be a bad transmission modulator, or worse. x2... check the vacuum lines going to the modulator, they dry out and crack often. It would be x3 John I already said vacuum modulator... And the vacuum lines do suck.. Even slight cracking can cause incorrect vacuum to it and it wont work 100% correctly Quote
GP1138 Posted June 21, 2009 Report Posted June 21, 2009 I will say that it might be a bad transmission modulator, or worse. x2... check the vacuum lines going to the modulator, they dry out and crack often. It would be x3 John I already said vacuum modulator... And the vacuum lines do suck.. Even slight cracking can cause incorrect vacuum to it and it wont work 100% correctly Ken originally said modulator... so I think you got cock-blocked there buddy. Quote
boymeetspavement Posted June 22, 2009 Author Report Posted June 22, 2009 thanks guys Ill take a look at the lines, Ive been just easing off the throttle slightly before shifting out of 1st and that eases the shifting to the point of it feeling normal. So far its been ok...see how it ends up. Quote
w-bodys_are_the_best Posted June 22, 2009 Report Posted June 22, 2009 Mine was actually worse at 1/2 to 3/4 throttle than at WOT. It was usually smooth at WOT. Quote
boymeetspavement Posted June 23, 2009 Author Report Posted June 23, 2009 Mine was actually worse at 1/2 to 3/4 throttle than at WOT. It was usually smooth at WOT. thats the strange thing, it only shifts hard when at 1/2 throttle and higher. I can make it shift nicely if I lay off the throttle. Quote
xtremerevolution Posted June 23, 2009 Report Posted June 23, 2009 What other people said. There should be a vacuum hose going down into the transmission, which as far as I could tell affected the proper function of the TCC. I made sure those were always in good condition and connected. Quote
Garrett Powered Posted June 23, 2009 Report Posted June 23, 2009 do you have a good motor mount or is it all sloppy and causing real hard shifts? Quote
GM Guy Posted July 1, 2009 Report Posted July 1, 2009 I had the same problem with my 95 GP w/ 4T60 E when it was new, felt like the B&M shift kit I installed on my 80 GP's Turbo 350. Culprit was one of the check balls in the valve body that created the problem. The dealer said the trans would have self destructed if I continued to drive it the way it was. It would chirp the tires going into second. Best thing to do for the meantime is to let off the gas completely before it shifts till you can get it fixed. Not easy as the side pan needs to be removed. Valve body needs to be checked closely for warpage but could be some trash making it stick or a film build up. Don't start thinking that you have an instant shift kit, far from it, the trans will fail. Quote
