Ribbie Posted September 5, 2003 Report Posted September 5, 2003 Any recommendations on a good spark plug to buy? Looking for something of good quality and not to mention great performance. Same goes for the wires. Car is a '92 Buick Regal GS w 3800 series 1 Cheers and thanks for any input. Quote
Brian P Posted September 5, 2003 Report Posted September 5, 2003 delco rapidfires and ACDelco wires (advance auto) or borg warner is fine Quote
grandprix104 Posted September 5, 2003 Report Posted September 5, 2003 rapid fires, reg. delcos, splitfires. NGK and Autolite are good plugs but not sure about em for our cars Autolite wires or BorgWarner all the way. Dont buy NAPA crap they break too easy. Quote
topless94style Posted September 5, 2003 Report Posted September 5, 2003 i read some article that split fires got f-ed up. Quote
Thabulldog Posted September 6, 2003 Report Posted September 6, 2003 I'm using bosch wires with bosch x2's, i get like 1mpg better and its a lil peppier Quote
Joe T. Squirrel Posted September 6, 2003 Report Posted September 6, 2003 I just replaced the original wires and a worn set of AC RapidFires with a Borg Warner "custom fit" wireset (if you consider one wire about three inches longer than any other wire "custom fit" ) and NGK V-Power plugs. Runs just as good as any other plug / wire I've had - no problems. I believe I'd read somewhere the Bosch plug problem was when the plugs first came out - since then it's been cleared up. YMMV. Good luck, JTS Quote
