The Parts Number Thread!!
HUD (Heads Up Display) adjuster for 91-93 Grand Prix.  Part #10063347.
Edited by jiggity76
Pontiac Grand Prix rear light bar housing.  Part #16508565.
Pontiac Grand Prix STE rear light bar lens (STE specific).  Part #16508573.
Pontiac Grand Prix rear light bar bulb gaskets (foam pieces that seals to the body and surrounds the bulbs).  Part #16508572.
1988-1991 CS hood "Oldsmobile" emblem.  Part #20695878.
1988-1993 CS International Series emblems (used on center console, both front doors, and trunk lid, certain years).  Part #10073643.
1988-1991 CS Oldsmobile Rocket center hood emblem (between the front grills).  Part #10109380.
1991-1997 CS DOHC 24 VALVE fender emblems.  Part #10134591.
GM security lock lug nut tool.  Please note: this is the part # for the tool, not for the security lock lug nuts.  Part #999057.
Edited by jiggity76
Pontiac Grand Prix ABS machined face with black font center caps.  These may apply to other Pontiac/GM ABS equipped models.  Part #09592275.
1991-1994 CS HUD (Heads Up Display).  Please note: this is for the HUD body with internal electronics.  Decorative cover (Garnet Red shown) comes in different colors to match interior of that particular car and may have a different part #.  Part #16163973.
1990-1993 Pontiac Grand Prix STE front light bar emblem (STE specific).  This is the red Pontiac arrow with "Special Touring Edition" lettering.  Part #16503785.
Edited by jiggity76
1990-1996 Pontiac Grand Prix front light bar housing.  Please note: this is not the lens, just the body or housing to which the lens mounts too.  The lens will be trim specific.  Part #16511882.
  • 2 years later...
Here's some more, some odd ones I actually may end needing...
Accelerator Pedal Lever Support
Part #: 25509808
Accelerator Lever Support Stud
Part #: 25509840
Lever Assembly, Accelerator Pedal
Part #: 12550602
Accelerator Pedal Lever Plate
Part #: 14094925
Accelerator control cable retainer, dash panel
Part #: 25607608
Nut Spg push on 11 diameter
Part #: 11501927
Cup Holder, Front Seat Folding Storage Armrest *Ebony
Part #: 12518654
Anti Lock Brakes
ABS Pump And Motor Assembly (18019214)
ABS Modulator (18060806) or (18024456)
ABS Relay (12088595)
ABS Wheel Speed Sensor ((10456116))
Brake Fluid Level Sensor (18012741)
Brake Master Cylinder Reservoir (19209212)
Modulator Lower Cover (18021868)
ABS Pressure Modulator Valve Motor Kit (18024456)
Master Cylinder (18029914)
Control Module (16154594)
Control Module Bracket (10063521)
Wire Harness Left Front (12140219)
Wire Harness Right Front (12167648)
Black Multi Purpose Relay for ABS (13502674)
Main Relay (12088595)
Black ABS Wheel Speed Sensor (10456116)
Part #: 25509808
Part #: 25509840
Part #: 12550602
Part #: 14094925
Part #: 25607608
Part #: 11501927
Part #: 12518654
Anti Lock Brakes
Which ones do you need?  I might be able to help and thank you for posting them.
  • 1 month later...
