The Parts Number Thread!!
White93z34
Someone suggested we have a Thread dedicated to parts numbers, And that is an excellent Idea. I'm going to keep this open and you can post whatever you feel is helpful to the community. I will be deleting the replys after I paste them into this Post to keep it uncluttered.
Unless noted these are Manufacturer Part numbers and will be the same regardless of who you buy from
Brakes:
Power Master III Parts:
88927271 / 18M874 - accumulator
88927270 - pressure switch
SIA Electronics - Call for pricing and parts (800) 737-0915
Goodridge SS brake lines:
'88-'90 W - GS12264
'94-'97 W - GS12237
Suspension:
GMPP rear trailing arms - 12498649
Police Package Impala trailing arms- 15856683 - QTY2
Hub to knuckle bolts(1 and 1.5 gen front only) - 10104548
KYB GR2/Excel G Front Sturts - 366004
KYB GR2/Excel G Rear Struts - 236003
Energy Suspension greasable poly sway bar bushings (when using 34mm front sway bar) - 9.5160G and 9.5167G
Rear sway bar bracket - 10259660
Engine:
Oil Filters:
2.8/3.1/3x00/3800 - PF47
3.4 - PF52
Note: You can use the PF52 on just about anything that calls for a PF47.
Knock Sensor (genII 60*)- 10456208
Crank Position Sensor (CPS) (GenII 60*) - 10456555
oil/distributor drive O-Ring - 10477565
Oil plug bolt thread size - M12-1.75
Oil drain plug - 10017615
aftermarket Magnetic plug - Motormite "Oil-tite!" 65372
Dorman Quick Disconnect 800-401 - Cooling System Connector that screws into the LIM of 3.1mpfi, earlier 3100sfi, earlier 3400sfi, and 3.4DOHC cars.
3.4 DOHC Timing Belt Parts:
24502982 - Belt
24503561 - Tensioner Pulley
10162013 - Tensioner Pulley Bolt
24503859 - Idler Pulley, 2 needed
24503860 - Tensioner Actuator
24503861 - Tensioner Actuator mounting plate.
89017825 - Improved aluminum Series II 3800 intake gaskets
2.8/3.1 Throttle Body gasket - Fel-pro 60728
91-97 LQ1 Solid rubber engine mount - DEA/Pioneer P/N - A2555 (Available from Autozone)
88-93 2.8/3.1 Solid rubber engine mount - DEA/Pioneer P/N - A2660 (Available from Autozone)
94-96 3100 Solid rubber engine mount - DEA/Pioneer P/N - A2796 (Available from Autozone)
97-04 W-Body Solid rubber engine mount(EXCEPT 3.5L Intrigue) - DEA/Pioneer P/N - A2796 (Available from Autozone)
2.8/3.1 Oil Pressure Sending Unit w/ Gauge (Seems to be for any 60 degree W from 89-90): GM part number 10201491.
Transmission:
4T60-E VSS - 10456034
4T60-E Parking Brake Actuator - 24213560
Getrag 284
Spec Stage II Clutch - SC272
Output Shaft Seals Timken P/N - 2003N
284 select cable - 10192248
284 Slave Cylinder - 12550806
282/284 Clutch pedal bushing - 14091384
Interior:
GM W-body Door Key "C": 12390306
GM W-body Ingition Key "D": 26002688
GM W-body Ignition key "E": 26024974
Body/Misc:
97-00 - Regal GS and Grand Prix GTP fuel pump resistor - 88951182
1st gen Hood release cable - 10167401
94-96 GP Fender flare Clips - 10229345
Power steering rack pressure switch - 10238816
Subframe Bushings
14088025 - QTY2
14088026 - QTY2
14088027 - QTY2
14088028 - QTY2
Subframe Bolts
10220561 - QTY4
Subframe Retainers
10139080 - QTY2
10203413 - QTY2
Fuel Tank Lines for 88-91 W bodys
10062887 PIPE ASM FUEL RTN
10062888 PIPE ASM FUEL FEED
AC Accumulator:
4 Season's PN# 33206 - VERY useful for 284 cars and Turbo Grand Prix
Edited by White93z34
Link to comment
Share on other sites
  • 3 months later...
1st Gen GP parts catalog scans:  Use the option to download the image and you'll be able to view them full size and also zoom in so you can clearly view all part numbers.
Edited by mfewtrail
invalid link
  • Like 1
Link to comment
I have the GP sedan parts catalog pages finally that I have been meaning to scan and post up as well. The GP coupe pages cover a lot but for the few body components that are different, the sedan pages should be a nice addition :)
Link to comment
  • 3 months later...
Injector O-rings:
multitech 1
BWD 274573 (formerly GP Sorensen 800-9220) brown silicone
*kit contains 12 o-rings, not 8 as sometimes listed
*half the kit will do the top half of multitech 2 injectors.
(carried by Advance autoparts)
*** BWD 274572 contains 8 rings... buy two and it can be cheaper than buying the 12 box
mutlitech 2
ACD# 217-1427 GM#12570621
Link to comment
  • 1 month later...
Poly Dogbone bushings, these require drilling:
Energy Suspension: 3-7103 R
R is for Red, you can get them in black is well which is G
These are torque arm bushings for a fiero
Link to comment
  • 3 months later...
  • 3 weeks later...
  • 4 months later...
  • 5 months later...
MOOG suspension bushings for GEN 1/1.5 sway bars (blue rubber? ones)
(34mm bar) inner: MOOG Part # K6457 {Sway Bar Bushing Kit} Front Suspension; To Frame; w/1-5/16" Bar
(all bars) outer: MOOG Part # K6641 {Sway Bar Bushing Kit} Front Suspension; To Control Arm
Edited by Crazy K
Link to comment
  • 1 month later...
  • 1 month later...
  • 7 months later...
I just tried to order a new vac spider #10114903 for my TGP from gmpartsdirect.com and the order was cancelled because the part is no longer available.
Figured that might be good info to get out there. These vac spiders are becoming harder to get.
Link to comment
  • 3 months later...
Something that is very recommended when doing deep engine work is to use revised problem solving intake gaskets so you don't have the risk of having to do the job twice, or worse. here they are:
3800 gasket sets:
FEL-PRO Part # MS98014T PermaDryPlus®; Intake Manifold Gasket Set
FEL-PRO Part # VS50465R PermaDry® Valve Cover Gasket
*head gaskets and upper intake gaskets may vary by application in normally aspirated verses forced induction*
3x00
Metal Intake Manifold Gaskets FEL-PRO Part # MS98004T PermaDryPlus®; with upper gaskets and seals. for SMALL port intake, L82 (Vin M)
Metal Intake Manifold Gaskets FEL-PRO Part # MS98003T PermaDryPlus®; with upper gaskets and seals. for LARGE port intake, LG8 3100 (Vin J), LA1 3400 (Vin E)
Link to comment
  • 3 weeks later...
  • 1 month later...
  • 8 months later...
LQ1 Cam gear bolt (94-up...maybe 91-93?)
These are the 4 bolts that secure the cam gears to the cams.
GM P/N 10127521
Link to comment
  • 1 month later...
Coolant Pipe. Original Thread Here: http://www.w-body.com/showthread.php/77468-repairing-ruptured-coolant-pipe
The original part is GM # 10145142. There's an aftermarket Dorman replacement, #626-100. They run about $30 shipped on eBay.
http://www.ebay.com/itm/DORMAN-626-100-Heater-Hose-/390597626865?pt=Motors_Car_Truck_Parts_Accessories&hash=item5af16ecbf1&vxp=mtr
A rubber hose might last longer, but the OEM style part should also last at least a decade.
Edited by runt
Link to comment
  • 1 year later...
Brakes:
'88-'90 W - GS12264
'94-'97 W - GS12237
Suspension:
GMPP rear trailing arms - 12498649 <- On indefinite national backorder
Engine:
Oil Filters:
3.4 - PF52
24502982 - Belt
Transmission:
Getrag 284
Interior:
Body/Misc:
Subframe Bushings
14088025 - QTY2
14088026 - QTY2
14088027 - QTY2
14088028 - QTY2
Subframe Bolts
10220561 - QTY4
Subframe Retainers
10139080 - QTY2
10203413 - QTY2
AC Accumulator:
I AM LOOKING FOR GM PART #24503861 DO YOU KNOW WHERE I CAN GET THIS. I KNOW THAT IT IS DISCONTINUED.
Link to comment
  • 3 months later...
for the most well done(crustiest) of w-bodies:
having to replace all of the fittings due to running new brake lines from front to rear, it appears that all of the line nuts in the braking system of the 95 monte carlo uses a M10-1.0 thread with the exception of 2 of the master cylinder line nuts, those appear to be M11-1.5. I imagine this applies to at least all w-bodies with ABS VI, but the non-ABS cars are probably similar/identical. can't speak for PM3.
Link to comment
  • 4 months later...
- Dorman trailing arm replacements (square tube, not U-channel like the stockers) p/n 905-501 (pair)
- Dorman trailing arm brackets to frame (these usually rot out) p/n 523-023 (97-up)
- Dorman front sway bar (33mm diameter) p/n 927-100 (97-up)
- Dorman rear sway bar (16mm diameter) p/n 927-110 (97-up)
- Moog "problem solver" front end links (urethane bushings, barrel nut, extra thick center section) p/n K700527 (97-up)
Link to comment
  • 5 months later...
  • 4 years later...
