toastemcutlass Posted September 5, 2003 Report Posted September 5, 2003 so i hate when my car makes a noise its not supposed to so the other day my right rear brakes where sqeeking so i replaced them and the rotors, this worked fine for about a week the the fronts where sqeeking so i replaced them and the the rotors. now when i drive there is a slip cherp out of the back again and it sounds like the rotors warped cause its not constant. has anyone had this problem before? im really pissed cuz i replace everything and its sqeeking. ps i know its the back cuz it stops when i hit the parking brake a little Quote
grandprix104 Posted September 5, 2003 Report Posted September 5, 2003 you can buy caliper lube and brake quiet and put them on when you install them. The lube keeps things from freezing up and usually you only need a small 99Cent packet. The anti-squeek stuff you spray on the back of the pad to reduce vibration. it is really cheap and you can find both at any auto parts store. Also spray em down with brakleen first. Quote
slick Posted September 5, 2003 Report Posted September 5, 2003 We use an anti-squeal that you apply to the back of the pads. It comes in a little red tube that we get from NAPA. Quote
DOHCRagtopguy Posted September 5, 2003 Report Posted September 5, 2003 The product you are referring to would be CRC Disc Brake Quiet, Part 5016 (4 oz bottle) or 5017 (12 oz aerosol). Quote
toastemcutlass Posted September 6, 2003 Author Report Posted September 6, 2003 i always clean and put high temp grease on the guide pins and on the surfaces of the pads, but thats not sqeeking its, i believe its the pads. it sounds like they are rubbing the rotor Quote
