fleetwoodguy79 Posted September 5, 2003 Report Posted September 5, 2003 Ok, Got it ordered through autozone but they didn't list a hypertech stat for 94 and up, just 91-93. So I got a 93 180* stat from Hypertech. It looks a bit bigger than the one I have in now, but I tried it anyway. It started leaking, so I took it back out. The gasket was totally screwed, and the thermostat was bent!! So I got a new gasket and some RTV sealent, and tried again. Same damn problem. Is the 93 housing different? Or is there something I am overlooking... I really need to keep this thing cool so any help would be GREATLY appreciated! Thanks everyone! Quote
Redfox340 Posted September 5, 2003 Report Posted September 5, 2003 Yes, the 1994+ housings are slightly smaller. Solution: possible to grind / cut down on the retaining edge? Or is the entire thermostat bigger in general? - Erik Quote
brian89gp Posted September 5, 2003 Report Posted September 5, 2003 odd, the lower intake has the same casting number between a 92 and a 94, or at least i thought so. Quote
fleetwoodguy79 Posted September 5, 2003 Author Report Posted September 5, 2003 What can I cut off? Can I hack the thermostat? Its bent already so I wouldn't see what the harm would be. Do I also need to hack up inside the radiator hose tube? Quote
Redfox340 Posted September 5, 2003 Report Posted September 5, 2003 What can I cut off? Can I hack the thermostat? Its bent already so I wouldn't see what the harm would be. Do I also need to hack up inside the radiator hose tube? That would be my first choice but since it's already in it's condition, you've got nothing to lose. Depending the size problems, you should be able to gring away on the thermostat. I would NOT grind the housing itself; that's not an option I would choose. - Erik Quote
