TeeJay3800 Posted June 8, 2009 Report Posted June 8, 2009 Hey guys, first post here in a LONG time. I still have my '90 Cutlass around and about 3 week ago a small wisp of smoke rose from my steering column. It went away after about 5 seconds and there was no noticeable smell. I drove it quite often during the next 3 weeks with nothing. Then again today the same smoke appeared, but this time it lasted slightly longer and there was a pungent odor. Then later in the day, the exact same thing again. Each time the car has been fully warmed up and driven for about 15 mins or so. Each time was also following a sharp left hand turn, but that may just be coincidence. Everything on the dash/steering column still works. Any idea what is causing the smoke and what I can do about it? Quote
Crazy K Posted June 8, 2009 Report Posted June 8, 2009 I am going to guess you were using the turn-signal??? You were most likely seeing lubricant smoking from a worn contact. I have been successful at re-habbing most of these earlier style switches, but if the contacts or plastic of the switch are worn or melted, you ned to replace it. Quote
mfewtrail Posted June 8, 2009 Report Posted June 8, 2009 That smoke is from grease burning on the turn signal switch. EDIT: Damn Ken's ninja quickness! Quote
TeeJay3800 Posted June 8, 2009 Author Report Posted June 8, 2009 Wow, those were some quick responses. Actually, I think that in at least one of the instances, the turn signal was NOT on. In case I'm right, is there anything else it could be? FYI, I would describe the smell as "hot"...almost like when using a soldering iron. Quote
Crazy K Posted June 8, 2009 Report Posted June 8, 2009 if the signal is worn out it could be sagging, and making unwanted contact, which would cause the same thing to happen. Quote
GP1138 Posted June 8, 2009 Report Posted June 8, 2009 I'm amazed that you haven't ever had this happen before. And good to see you on here!! Come back more often! Quote
TeeJay3800 Posted June 8, 2009 Author Report Posted June 8, 2009 if the signal is worn out it could be sagging, and making unwanted contact, which would cause the same thing to happen. So either way, it's definitely turn signal related. What can I do to fix this problem? I'm amazed that you haven't ever had this happen before. And good to see you on here!! Come back more often! Thanks man. Maybe I will...especially if my Cutty keeps having problems! Quote
Regal_GS_1989 Posted June 8, 2009 Report Posted June 8, 2009 I had this happen on my cutlass. All I did to fix it was remove the steering wheel and the signal switch, then clean off all the grease from the contacts. Once that was clean, i bent the contacts ever so slightly so that they made better contact, put a small amount of fresh grease on the contact points only and put it all back together. Worked great up until I sold the car. Quote
Crazy K Posted June 8, 2009 Report Posted June 8, 2009 I had this happen on my cutlass. All I did to fix it was remove the steering wheel and the signal switch, then clean off all the grease from the contacts. Once that was clean, i bent the contacts ever so slightly so that they made better contact, put a small amount of fresh grease on the contact points only and put it all back together. Worked great up until I sold the car. done this on every car. Only one of mine had gotten so hot it melted, and that one had to be replaced. Quote
Brian P Posted June 8, 2009 Report Posted June 8, 2009 Yeah my '90 did the same thing back in the day, lol. My mother drove it, noticed it, and freaked the hell out! It was the switch like everyone has said. Quote
digitaloutsider Posted June 8, 2009 Report Posted June 8, 2009 Come on, Tim. I'm disappointed you'd need to ask this Quote
GP1138 Posted June 8, 2009 Report Posted June 8, 2009 Yeah my '90 did the same thing back in the day, lol. My mother drove it, noticed it, and freaked the hell out! It was the switch like everyone has said. Same with my wife when it happened to me, she wanted to get out of the car like it was on fire. Quote
5speedz34 Posted June 9, 2009 Report Posted June 9, 2009 Holy shit! Guess who's back! I'm happy that you still have the Cutlass! Quote
GOT2B GM Posted June 9, 2009 Report Posted June 9, 2009 hahahah this is a normal occurance in a 1st gen. My old Z, my old vert and my I think my new Z does it on the odd occasion for a second. Quote
