19Cutlass94 Posted June 8, 2009 Report Posted June 8, 2009 Is there anyway to correct dash gauges? My volt gauge is WAYY out of wack. Ill be at 14 volts and its reading 11. Is there anyway to fix this or an I stuck with it that way? Quote
jrcuttymann Posted June 8, 2009 Report Posted June 8, 2009 Take it apart and physically move the pointer possibly Quote
Crazy K Posted June 8, 2009 Report Posted June 8, 2009 NO... it sounds like you have a genuine voltage issue. how have you determined you have 14 volts? Quote
19Cutlass94 Posted June 8, 2009 Author Report Posted June 8, 2009 Voltage at the battery is about 13.8-14.0 volts. But at the same time my gauge is ready about 11. Quote
Crazy K Posted June 9, 2009 Report Posted June 9, 2009 Voltage at the battery is about 13.8-14.0 volts. But at the same time my gauge is ready about 11. try to measure at the guage source? Quote
RobertISaar Posted June 9, 2009 Report Posted June 9, 2009 Voltage at the battery is about 13.8-14.0 volts. But at the same time my gauge is ready about 11. try to measure at the guage source? there is the possibility of the wiring being shot, or a loose connection somewhere, or maybe the actual guage has gone to hell, all are very likely. did it slowly come to this or one day, BAM, now its 11? Quote
19Cutlass94 Posted June 9, 2009 Author Report Posted June 9, 2009 For the most part, my gauge never touches 13v. Ken, at what point does the gauge take the reading? Quote
Grand Moff Joseph Posted June 9, 2009 Report Posted June 9, 2009 I'd say swap the gauge first, as that's the easiest thing to do. If that fails to help, look at the wiring. Quote
cubsfan24 Posted June 13, 2009 Report Posted June 13, 2009 Check out this video from my favorite youtube channel http://www.youtube.com/watch?v=oyw1-OG6Guw Starting @ 4:00 He got a 94 regal that had a bad alternator and after he change it the dash read ~11 volts and the battery had ~14 volts. He tightened the B+ battery terminal and the gauge went up to ~14 volts. Don't know if its the same problem but its a easy thing to check at least. Oh and the videos are hilarious and a bit adicting. Quote
