mitalie Posted June 2, 2009 Report Posted June 2, 2009 I have a '95 Cutlass convertible with a 3.4L. It cranks fine when cold, but VERY slow when hot. Any suggestions anyone? I have been told three things. 1. Thermal blanket for starter - Starter is less then 1/8" from oil pan which makes this impossible. 2. Starter problem. 3. Battery - I took the battery to Autozone and they said it is fine, however I don't think they put it under a load condition with the handheld device he checked it with. Quote
95cutty96 Posted June 2, 2009 Report Posted June 2, 2009 Check the resistance that the starter is pulling while cranking had that same problem and had to replace the starter Quote
RobertISaar Posted June 2, 2009 Report Posted June 2, 2009 as far as battery testing, they either did it with a multimeter (wrong) or they had a handheld device similar to a blow dryer in that it heats up an element and measures the voltage of the battery while its under load(the correct method) Quote
stevegasm Posted June 2, 2009 Report Posted June 2, 2009 If you have a multimeter handy, try checking how much voltage there is while the engine is running. The alternator could be overcharging the battery, leaving it with no crank amps while it's hot. Worth a gander Quote
RobertISaar Posted June 2, 2009 Report Posted June 2, 2009 If you have a multimeter handy, try checking how much voltage there is while the engine is running. The alternator could be overcharging the battery, leaving it with no crank amps while it's hot. Worth a gander its been a while since i've seen an alt overcharge a battery but it is a possibility. Quote
