digitaloutsider Posted June 2, 2009 Report Posted June 2, 2009 Does anyone know off hand what inner/outer diameter the cat on the TGP is? I'm guessing it's 2.25" but I don't really have a clue. I'm getting the mandrel bent exhaust put on tomorrow and I need to know if I have to pick up a cat. Thanks! Quote
GOT2B GM Posted June 2, 2009 Report Posted June 2, 2009 Pretty sure its 2.25, but its been a couple years since I've swapped the cat on it. Is that Marks Mandrel system? I have mine that has to go on the TGP as well Quote
digitaloutsider Posted June 2, 2009 Author Report Posted June 2, 2009 Yeah, that's what it is! I'm excited to hear what it'll sound like. If it's 2.25" I'll leave it since that's all the downpipe is anyway, IIRC. Quote
GOT2B GM Posted June 2, 2009 Report Posted June 2, 2009 Putting mufflers on it? I'm going to add an 18" resonator in the stock 93+ location, and go mufflerless. Should sound good. Quote
GOT2B GM Posted June 2, 2009 Report Posted June 2, 2009 IIRC the tgp system is 2.25 to the Y where it goes to 2" Quote
digitaloutsider Posted June 2, 2009 Author Report Posted June 2, 2009 I'm gonna run mufflerless as well. I have a resonator, but there's really nowhere to put it. I think I could put it after the 90 degree bend (excuse our filthy floor, we had tons of people over this weekend): it doesn't look like it'd work right after the cat with the way it bends up to meet the cat and all: Quote
LukeZ34 Posted June 2, 2009 Report Posted June 2, 2009 Good.. that car needed exhaust. Stock was just too quiet.. but it held up well for it's age, gotta give it that much. Quote
94GPGTP Posted June 2, 2009 Report Posted June 2, 2009 yea its 2.25.. i just cut mine out hmmmmm maybe 3 weeks ago.. Quote
Garrett Powered Posted June 2, 2009 Report Posted June 2, 2009 I just ordered a vibrant 18" ss resonator for my 2.5 aluminized system. I will probably hold on to the 3" ss system for a while until I decide which car to put it in. what brand and length did you go with? and where did you get it? I paid $76 shipped from sfx but they are taking forever to get it to me. I will be going mufflerless at first to see how it is. but I don't know what tips to get yet. pretty sure I won't be using stock though. I gotta experiment with the cheaper system I got first. got lucky and only paid $115 for it but I'm sure it will be several hundred before it's all said and done. Quote
slick Posted June 2, 2009 Report Posted June 2, 2009 The exaust system that I gave with you is 2.5" aluminized. Not sure if you knew that or not, but I wouldn't bottleneck the system with a 2.25" cat. EDIT: Granted that the downpipe does limit the exhaust flow, I'd go with 2.5" for everything. IIRC, there is someone working on custom crossovers for the TGP's with larger downpipes. Quote
digitaloutsider Posted June 2, 2009 Author Report Posted June 2, 2009 Yeah, I know it's a 2.5 system, but with the 2.25" downpipe and the fact that I don't plan on every upgrading it, I don't feel it's worth the extra cost. I just want something a little nicer under the car for now. Quote
slick Posted June 2, 2009 Report Posted June 2, 2009 Gotcha. The best prices I seen for cat's was on Amazon. That included shipping. Quote
digitaloutsider Posted June 2, 2009 Author Report Posted June 2, 2009 UPDATE: a TGP with no exhaust from the cat back sounds sweet You hear the turbo spool waaaay down. It's like a turbo diesel! Quote
GOT2B GM Posted June 2, 2009 Report Posted June 2, 2009 Sweet! I have to get on this myself. I have a Vibrant 18" SS resonator and was planning on putting it beside the gas tank like yours. I also have a 2.5" cat, and a 2.5" electric cutout for before the cat. I plan on wiring it to a factory performance sound switch using a relay. I'm going to buy some 2.5" OD aluminum tubing and have my cousin or uncle TIG weld 4" lengths of it to the back of the factory tips, coping out the old inlet and material blocking the new 2.5" inlet. The tips will slide into the 2.5" piping and be clamped on like stock. Quote
digitaloutsider Posted June 3, 2009 Author Report Posted June 3, 2009 Got the new exhaust on. I can stay two things; A.) the exhaust was certainly not designed with TGPs in mind and b.) it was not designed for use without mufflers. There was a lot of modification required to make it fit right, and in the end we just said fuck it and aligned the pipes so aftermarket straight tips will line up right. The stock TGP tips are angled/bent to make up for how wonky the stock mufflers fit. So basically that means my stock tips are sitting about an inch and a half too low, but whatever, fuck it. It's on the car now and I just need to find some good aftermarket tips. The video really doesn't do justice. It sounds great in real life. Quote
jake91 Posted June 3, 2009 Report Posted June 3, 2009 a bit loud for my tastes, but overall it sounds awesome. Quote
Addicted To Boost Posted June 3, 2009 Report Posted June 3, 2009 Sounds nice! It doesn't seem as loud as I thought it would be. I'm not so sure I like the sound of the 3400 starter now. Quote
mediabandit Posted June 3, 2009 Report Posted June 3, 2009 Sounds good for not having any mufflers on it. I know it must sound much better in person, recordings never give it justice, i know, because mine sounds much better in person as well. I know when Mark did the design for those, he used the lumina as a test platform, that is probably why it didn't have the right placement for the TGP. On another note, the car looks like it is in awesome shape. Quote
mfewtrail Posted June 3, 2009 Report Posted June 3, 2009 Has the same tone as mine(black), but I'm sure it's louder since yours is catless. Looks like someone put 2 of my old videos up on youtube, I saw them on the sidebar after watching your video. Quote
GOT2B GM Posted June 3, 2009 Report Posted June 3, 2009 What exact modifications were needed? Could you please post pictures of the install? Quote
digitaloutsider Posted June 3, 2009 Author Report Posted June 3, 2009 We ended up putting the resonator after the 90 degree bend because the length of pipe they used there was not long enough to clear the monoleaf. Without it, the exhaust split directly under the spring. The left side of the exhaust (the part that connects to the Y) had to be custom fabricated because it's designed to be used with stock W-body exhaust components, not a mufflerless setup. This would probably be a lot easier to fab up if you're not dead-set on having the stock tips. I'll try and get some good pictures tomorrow. The ones I got tonight didn't come out well. Quote
TheAviator Posted June 3, 2009 Report Posted June 3, 2009 Got the new exhaust on. I can stay two things; A.) the exhaust was certainly not designed with TGPs in mind and b.) it was not designed for use without mufflers. There was a lot of modification required to make it fit right, and in the end we just said fuck it and aligned the pipes so aftermarket straight tips will line up right. The stock TGP tips are angled/bent to make up for how wonky the stock mufflers fit. So basically that means my stock tips are sitting about an inch and a half too low, but whatever, fuck it. It's on the car now and I just need to find some good aftermarket tips. The video really doesn't do justice. It sounds great in real life. Awesome! I can't wait to hear it in person. Quote
AWeb80 Posted June 3, 2009 Report Posted June 3, 2009 sounds great. a bit loud, but the same tone I want for my GP..... I'll have a vid up of mine soon Quote
