front wheel bearings/hub assly.. valucraft?
is valucraft actually valucrap?
also they have timken at autozone.
and there is a napa premium if its worth the money.
I just looked at my National bearings and they are already wobbly a little and they only have been on there since 2006 and maybe 10-30k, I can't remember exactly, but recently done. I expected them to last a good 50k easy, but noooooo.
I need opinions. thanks.
after doing a little searching I think the extra $20 for the timken would probably be wise.
also I heard to torque them properly at 250 ft/lbs, so I'll make sure to do that.
timken all the way.
X2
I had to change my front left on my old 92 lumina after hitting the curve while turning and accelerating. boy was that stupid :facepalm:
250ftlb???? Where did you get that spec??
They should be around 110... I will get you the actual spec of Mitchell later...
thought the cv nut was around 150 ft lbs
the little bolts are only like 40-50 ft lbs
NAPA premium is more then likely a better brand like Timken or Federal-Mogul repackaged.
Timken is FTW, for the cost difference it plain out does not make sense to buy cheap suspension stuff because it will fail sooner then later
I just picked up the timken one from autozone.
$99 - made in the USA.
he said it was for sure way better than the valucraft too.
fuck valuecraft, i wont even buy their rotors. definitely timken.
axle nut is 184 ft-lbs.
bearing-to-strut tower bolts are 58-61 ft-lbs, somewhere in there. though i've had several snap before the wrench ever clicked @ that spec.
250 is way too high. trust me, i've looked these up in the service manual within the past 3 days.
