The last couple months, the clear coat on the drivers rear fender (up top by the trunk), has started peeling off... As one may guess, it looks horrible on a maroon car... I was wondering if there are any solutions as far as removing the clear coat that has begun peeling and maybe spraying on some new.. I know the ultimate solution is a repaint, but I do not want to sink that kind of money into a car we are going to be getting rid of this fall... I just want it to look better than it currently does.. I can get pics if necessary.
Thanks guys!
Honestly Im no bodyman but you probably wont be able to get away with sanding off the clear and respraying it. Ultimately you will just have to get the whole car repainted to fix that issue, which unfortunately is very common on GM cars from the early to mid 90s.
single stage color match and a pre-val sprayer.
thats what I did on my rear bumper and you couldn't tell from 5ft away.
Whats a pre-val sprayer?
x2. I have some clear coat to redo on the jag.
its a glass jar that screws on to the bottom of an aerosol can top. there is a pickup tube that goes down into the jar and it works just like a regular can of spraypaint. you could spray clear through it if you wanted. it will have orangepeel finish but wetsand and buff it out.
http://store.fastcommerce.com/cat_PaintProsUSA_ff80808117344aab01175581fc276445.html?gclid=COj1xef54poCFQwxawodFnGTAQ
