kuntzie Posted May 26, 2009 Report Posted May 26, 2009 motorswap.org tech artices arent working and im trying to find out how to do the reverse lights... i kept the shifter module that sits on top of the trans in the car aswell as the wiring of course... i have it currently set in "park" to be able to crank it.. im most positive at least one wire on the 2 connectors attach to the sensor on the 5-speed. any input? Quote
Guest Posted May 27, 2009 Report Posted May 27, 2009 http://www.w-body.com/forum/index.php?topic=61879.0 Quote
kuntzie Posted May 27, 2009 Author Report Posted May 27, 2009 this is a 284 and 4t65-e.... im prettyre sure i use light green and pink for mine as far as i can remember.. (light green for revers signal, pink for the accessory wire.. then to eliminate the shift selector thing i can attach the bigger yellow wire and purple wire on the same thing Quote
Guest Posted May 28, 2009 Report Posted May 28, 2009 Oh wait, so this is in the 2001 then? humm. Well, I would check the owners manual or fuse box labeling to find the reverse light fuse, then match the wiring colors with those on the 4T65. Or at least find one of the wires that way and connect it to ground and confirm that the lights come on. Quote
