Ok so I have a missfire, and I smell a very very strong fuel odor.
I get a nice puff of blueish smoke if I give it gas, along with the fumes smelling very strong of fuel odor.
I have taken the plug wires off the front 3 plugs, they all gave spark, but only two changed idle speed when I pulled them off. One does not.
The coil I suspect (the one that does not change idle speed when pulled) still give off a spark, not as strong as the others however, and kind of sparatically sparks.
Would you say this is a coil problem as well.
This is my 92 Lumina 3.1
should have consistent spark on all coils. change out the culprit and check all the plugs for fouling.
