93 Z with 94 motor and harness, injectors stuck on
And ideas on a cause? Does anyone know of an electical difference between 93 and 94 that might cause this? I know that's when they switched to obd 1.5 but everything from the firewall forward is from the 94. Also open to suggestions on how to remedy this problem. Tryin to revive my dads z after 3 years of sittin.
OHM Checked them?
you might have a leak down.
If you want to convert back to OBD1 I have a entire harness and PCM from a 92/93.
wait... is it actually switched... or did they just plug the WRONG harness in?
The harness is correct for the motor. If you connect the battery cable you can hear the injectors kick on.
the fuel pump is kicking on as well?
  robertisaar said:
  jdcutty said:
The harness is correct for the motor. If you connect the battery cable you can hear the injectors kick on.Â
Negative
THAT MEANS NOTHING.
Is there a 94 harness on a 94 motor hooked to a 93 C100 connector? that = MASSIVE FAIL!!!!!!!!!!!!!!!
What PCM is hooked to it now? 94 or 93?
Unless you are trying to CONVERT TO OBD 1.5... (WTF WOULD YOU DO THAT???) You should be using the 93 harness with the 93 PCM. and YES, you can use the 94 motor... but you need the 93 harness!!!!
That is the answer I was looking for. Thanks ken. Guess I'm off to chase down some sensors.
sorry to be rash... but you made my head hurt!
good luck, and keep us posted if there are further issues.
will do. we just looked at the 93 harness and found a couple of cut wires so we gotta figure out where they go. should be all sorts of fun.
well... the 93 and 94 harness are similar... except:
front cam sensor
crank sensor in timing cover
individually fired injectors vs batch fired (number and arrangement of wires)
C100 connector (the firewall connector, btw)
PCM wiring and connectors.
alternator.
in general, you could get some idea of what to do and repair from the 94's harness.
stick with the 93 harness, which can be installed on the 94 engine... make all repairs necessary to the 93 harness.
Goto a j/y, pull an intact 93 LQ1 harness, use 93 sensors, and a 93 ECM
the one we have is complete minus 3 or 4 wires. shouldnt be too much of a problem. we are just gonna pull the motor back out and rewire it.
good call, much less stuff to cut your hand on that way, and much less frustration
  • 2 weeks later...
yeah you would think so...
