Update your list!
I hate my car! Problems are
1. Coolant leak under supercharger snout at the elbow.Fixed/color]
2. It Creaks and pops in the front end when giving gas for the past 1,000 miles
3. Blown motor mount
4. Needs coolant flushedFixed/color]
5. Needs a new auto dimming rear view mirrorFixed/color]
6. Needs a driver side window motor/regulatorFixed/color]
7. Needs exhaust leak fixed
8. Needs a/c Re-ChargedFixed
9. Needs exhaust tips
10. Needs hood/Drivers side finder/bumper.
11. Needs hood/Drivers side finder/bumper/ Drivers door/ drives rear ¼ panel painted right
12. Front swaybar fixedFixed/color]
13. New End links installedFixed/color]
14. New strutsFixed/color]
Mine (91) leaks oil in 2 places, leaks trans fluid, leaks coolant, and leaks power steering fluid.
It needs a clutch and it needs to stop knocking and it needs a new power lock solenoid or whatever... It needs a valence and it needs all of the fluids listed above that leak
Mine needs engine and trans and computer at least the cutlass the lumina needs someone to put the engine and trans and pcm from the cutlass in it that's about it hopefully but it is a w body so I'm sure it will always have something that can be fixed
My '91 Bonneville (not a W-body, I know) needs:
1) the rear struts replaced BADLY (the damn thing bounces like a trampoline and practically does a 90 degree rotation when driving around bumpy curves)
2) catalytic converter/heat shield removal (its got that ugly rattle, plus the car has such high mileage it wouldn't hurt to do it)
3) new camshaft position sensor
4) a transmission treatment (likely has a gunked-up throttle valve because the transmission is a little rough or jolting)
5) COOLANT!! shit, I forgot about that!!!! Oh well, it's only a little low....
Immediately needs:
New wheel speed sensor/hub
New tires
WASHED
Very soon to need:
Pads and rotors
Would very much like to replace:
Windshield
Need to get done:
Exhaust tips
I would post my list but it gets longer by the minute LOL. The toppers are get the interior finished, fix the oil leak, and get the heater box and door fixed.
Side mirror (have one to put on)
Exhaust weld (don't want to.. like the sound)
Window motor? (not sure.. dreading looking at it)
New windshield (insurance will replace)
Touch up rock chips in the front end (blah)
Front brakes (blah)
In all honesty, nothing. I hate when repairs gang up since I maintain 4 W's at a time... so as soon as something breaks I fix it that day or the next.
pads/rotors all the way around
suspension work all the way around
new engine mounts
to be bitch slapped with the "Anti-Rattle/Squeak/Noise Machine"
1 hood
2 new exhaust
3 new cable for hood release ( replacing with pins with new hood)
4 new paint
5 new switch for signals( works but wearing out, maybe a rebuild will work?)
6 rear pads ( got em, need to not be lazy and do it)
Im sure Ill find alot more, Im sanding out the rear underside and spraying everything black cause of the rust near the exhaust.
91 GP:
Needs to run :willynilly:
Then it needs A/C and some new tierod ends.
TGP:
Leaking trans oil pan gasket
Needs fuel pump replaced
Needs struts bad
new horns
screw in tire fixed
oil change
oil change
a/c recharge
ball joint(i think)
may possibly need a lower engine mount
brakes all the way around
fuel filter
plugs and wires.
leaking tire fixed
shitty pacesetter headers replaced by stock exhaust manifolds
3" DP
rust on driver side 1/4 panel fixed
rear view mirror replaced
possibly 02 sensor (dont know until i fix the shitty headers)
A miracle
Actually it need me to get off my lazy ass, and finish dropping that new motor in. It also needs:
PMIII installed (and hope to god it works)
clutch slave/master installed
new PS pump
brakes all around
better tires (starting to rot)
wheel bearing
HUD fixed
DIS installed
hood (it keeps hinting to me it needs a good white hood, I say, "What? are you f@#*ing racist?)
a new maroon AQ9 driver's seat (this one is impossible)
cd player or any kind of stereo
entire exhaust system
battery
It really just needs a shit ton of money thrown at it, which I don't have. I am hoping to drive it before the snow falls at least once, but we'll see what happens. I've got almost $3000 into it the way it sits now.
A driver side mirror glass as moisture got in behind the glass and fucked up the autodimming fluid.
I also replaced the front brake rotors this past weekend because they were warped.
It could also use a detail job, but thats not a need.
Some very minor rust.
Gas gauge. I have the fuel pump at home but lack the time.
I have a surge or something when the torque converter locks up for the first time. Not sure if it's in the trans or if it's a plug/wire issue. So that needs fixed.
Plugs/Wires are due to be changed.
Coolant flushed.
Tranny pan dropped - New fluid/filter or maybe a complete flush I'm not sure.
That's about it. I shouldn't complain because it's been pretty good up until just this year.
So its your car that left an oil spot in my garage! :willynilly: What, the rusty crusties werent enough :lol: :lol:
fix wiring(i think) to make it run right
get a/c working
replace turbo coolant return line
replace right rear brake line
new pads and rotors
new tires
new paint
