iceturbo Posted May 17, 2009 Report Posted May 17, 2009 Hi, I have a 02 police impala and I was wondering, I know that I can put a 3.8 supercharger on it but what else I need??? Is the super charger and ECU is enough or I have to change a lot of things including heads? If the supercharger is too complicated, what do you suggest if I what to have a little bit more power? Thank you very much! Quote
AL Posted May 17, 2009 Report Posted May 17, 2009 Here is a kit from ZZP to properly supercharge your car https://www.zzperformance.com/grand_prix/products1.php?id=382 Search there site and you will find many other things you can do to your car... One of the first things I would suggest is cleaning your throttle body... Just take it off the intake and remove the sensors and spray it with a ton of carb cleaner... It brought back a ton of performance when i did it to mine and it only had 86k when i did it... 3800s are notorious for having that issue Quote
