3.1 Crankshaft Position Sensor
Hey guys-
Could someone tell me where on my 3.1 MPFI I will find the Crankshaft Position Sensor? Also, how does one go about replacing it.......is it farily easy......or fairly complicated? I tried the search function with no luck....
Anyways, thanks!
SmoothSteve3
1990 Chevy Lumina
3.1 Liter V-6
Ride on White Lightning
back of the engine block.
to get to it rotate the engine forward like if you were changing the back plugs, then look straight down the block under the middle cylinder and you'll see it. i believe its an 8mm bolt
