RUNDLC Posted May 14, 2009 Report Posted May 14, 2009 I "Think" I need to replace the injectors in my 94 3.4L DOHC (running 93 ecm) The car seems to run fine for the most part, when it is idleing it kinds has a slight miss, but rev it up and she seems fine. This is a stock crate motor w/ 5 speed with about 250 miles. I live in Cali and I want to prepare to go to the referee's station as this is in my lambo replica, the smog police have to check the install. Thanks RUNDLC Quote
Brian P Posted May 14, 2009 Report Posted May 14, 2009 I wouldn't change anything without doing a diagnosis to see exactly what's going on. Many other things can cause a slight miss at idle. Did the injectors come with the crate motor, or are you running some used ones? Quote
RUNDLC Posted May 14, 2009 Author Report Posted May 14, 2009 BP, they are used, I bought some from a forum member but they were no good, A buddy had some extras and we ended up using his. They have worked up until now but the miss eats at me. I will get someone to hook it up to see. Quote
