My 92 grandprix with a3.1 runs normal cool but once warmed up
has no power acts and sounds like timing way off if you shut the car off and wait like 30 sec sometimes it will run right for a few miles . no check engine light, its not a skipping and it will run like this for few miles and take right off like it was never running bad . I was thinking control modual on its way out any ideas
could be the ign control module, maybe even the O2 sensor... lots of possibilities in all honesty (MAP sensor too)
My guess would be the ignition module. You can take it off and O'reilly or Autozone can test it. My other guess be a bad crank sensor.
thank you for the help guys . I changed the module with a spare one i had and it runs perfect now :cool:the old one was coverd in oil from
aleaking valve cover gasket that i also fixed today im sure all oil that did not help it any.
