GPX Posted May 11, 2009 Report Posted May 11, 2009 I've had a creaking noise up for a while when I turn. More in one direction than the other. I had it up on jack-stands over the weekend and turned the wheel--sounds like it's coming from the rack. What is it? Quote
Brian P Posted May 11, 2009 Report Posted May 11, 2009 could be the struts or spring mount/bearings. It's gonna be hard to tell without getting under the car and checking for worn parts. Quote
Leadfoot Posted May 21, 2009 Report Posted May 21, 2009 Grease all your tie rod ends, etc. I have seen this many times before. Could be the rack, but I would put money on tie rod ends being dry. Sometimes it can also be the top of your strut being dry. This is a little harder to get at and lube, but its not too bad. Quote
RobertISaar Posted May 21, 2009 Report Posted May 21, 2009 well, if it was the rear of the car, i would have said balljoints, but yes, lots and lots of lubing should help Quote
xtremerevolution Posted May 21, 2009 Report Posted May 21, 2009 balljoints at the rear of a w-body? umm.... Quote
RobertISaar Posted May 21, 2009 Report Posted May 21, 2009 wait... i don't know why the hell i put ball joints... Quote
GOT2B GM Posted May 25, 2009 Report Posted May 25, 2009 well, if it was the rear of the car, i would have said balljoints, but yes, lots and lots of lubing should help no comment Quote
GP1138 Posted May 25, 2009 Report Posted May 25, 2009 yes, lots and lots of lubing should help no comment All he's saying is that you have to lube the shaft up a lot. Quote
GPX Posted May 26, 2009 Author Report Posted May 26, 2009 Grease all your tie rod ends, etc. I have seen this many times before. Could be the rack, but I would put money on tie rod ends being dry. Sometimes it can also be the top of your strut being dry. This is a little harder to get at and lube, but its not too bad. WIN!!!!!!!!!!!!! I finally got my Luger Luber working and lubed the tie-rod ends (front and rear ) and that took care of it. Thank goodness. Plus put new spring slider pads in rear--no more squeaks anywhere! Quote
SrMichi Posted May 26, 2009 Report Posted May 26, 2009 Where exactly are the different points on the car that should be lude up frequently? Quote
Brian P Posted May 26, 2009 Report Posted May 26, 2009 This thread is full of confusion what tie rods in the rear did you lube again? Stock, there's no true lube points on the car. All joints are sealed and maintenance free. Replacement joints, however, usually aren't and will require periodic lubing. Quote
GPX Posted May 27, 2009 Author Report Posted May 27, 2009 This thread is full of confusion what tie rods in the rear did you lube again? The rear ones! :lol: :lol: Quote
GPX Posted May 27, 2009 Author Report Posted May 27, 2009 Stock, there's no true lube points on the car. All joints are sealed and maintenance free. Replacement joints, however, usually aren't and will require periodic lubing. So I have replacement tie-rod ends? I say that because there def were grease nips (I like that cuz it sounds kinda dirty, and they were VERY dirty). Why would they make a maintenance-free part that wears out? Or did I just answer my own question? Quote
Brian P Posted May 27, 2009 Report Posted May 27, 2009 Yeah, they were replaced at one point then. Quote
