patgizz Posted May 8, 2009 Report Posted May 8, 2009 problem: 2001 intrigue w/ 3.5 shortstar - differential exploded. trans is otherwise assumed fine as it was rebuilt (clutch packs and seals) within 20k miles. potential solution: 1996 lumina parts car w/ good trans question: can we take the differential and potentially housing if necessary and swap from lumina to intrigue? Quote
slick Posted May 9, 2009 Report Posted May 9, 2009 Just asked Rob, he says nope. I'm sure he will get on later to explain the differences. Quote
White93z34 Posted May 9, 2009 Report Posted May 9, 2009 FUCK. I just gave away a 4t65e that had a good diff. if you want I can see if he still has it and would let the diff plus cover go. but IIRC the 3.5 intrigues got 3.29 gears so the diff from any L36 or LX5 gen 2 w body should work Quote
patgizz Posted May 9, 2009 Author Report Posted May 9, 2009 hmm. not really concerned with gearing if it ends up with a 3.33 gearset, just need to get the car on the road. what has to come off to get to the diff? the housing behind the engine or the big cover on the drivers side? i've never had one of these apart that far. Quote
Crazy K Posted May 9, 2009 Report Posted May 9, 2009 hmm. not really concerned with gearing if it ends up with a 3.33 gearset, just need to get the car on the road. what has to come off to get to the diff? the housing behind the engine or the big cover on the drivers side? i've never had one of these apart that far. the car will probably not run with the wrong ratio, as the computer would think the transmission was slipping. sounds like you need to run to PNP and find a second gen, with the info on hand on how to tell which diff is which. Quote
Brian P Posted May 9, 2009 Report Posted May 9, 2009 hmm. not really concerned with gearing if it ends up with a 3.33 gearset, just need to get the car on the road. what has to come off to get to the diff? the housing behind the engine or the big cover on the drivers side? i've never had one of these apart that far. Remove axle, and Just the diff cover from the passenger side, and pull it out. Quote
