Dannymik Posted September 1, 2003 Report Posted September 1, 2003 I want to clean the throttle body on my 3100SFi. Can you guys give me instructions on how to remove the TB and then a recommended cleaner for it. I thought I read that brake cleaner can be used :? . And do you have to replace any gaskets or o rings in the process. My car has 75K on it so it might have some shit blocking any air from getting in there. Thanks in advance! Quote
ismellrealbad Posted September 2, 2003 Report Posted September 2, 2003 i just did this last night. i used brake cleaner and it worked fine but i dont know if thats whats techincally s'possed to be used. its pretty easy, being that i am a mechanical idiot i was still able to do it. ill tell you what i did but im sure somone here will have a more proper or politically correct way of doing it. First u remove ur air box & ducting/intake, obviously. next i took that black bracket off the top. theres 3 screws 8mm i think 2 on top one kinda hidden below. the bottom one is a nut. then theres 3 bolts on TB. one on the left, right, and right bottom. the right bottom is a pita. theres a nut holding a coolant passage to it and once u remove that nut you need a deep socket because its threaded onto the stud you need to remove. i had my dad hold it out of the way while i undid it. thats about it and i didnt need to replace anything. i was about to bypass the tb heater while i had it off but didnt have any suitable hose laying around. oh yea.....and make sure the throttle and CC cables do NOT pull off the ends. they are a huge pita to get back on! Quote
Dannymik Posted September 2, 2003 Author Report Posted September 2, 2003 thanks smell...how many miles are on your gp? And you said that it made a difference? Quote
ismellrealbad Posted September 2, 2003 Report Posted September 2, 2003 over 86k.......and um yeah my car actually peels out now. amazing Quote
Dannymik Posted September 4, 2003 Author Report Posted September 4, 2003 I cleaned the TB just now...not that bad of a job. It was caked with dark brown shit, but not to bad for 75,000. I used carb cleaner and tried a little brake cleaner. Both worked equal. I brake torqued to about 2200 rpms and tore loose for a bit, which doesn't happen to often! Thank you smell for the help...a cleaner TB is always a plus ! Quote
mdelorie Posted September 5, 2003 Report Posted September 5, 2003 BRAKE CLEANER? :shock: I was told that even carb cleaner was too harsh for a EFI TB. so, I used some TB cleaner, worked great. Quote
91GranSport Posted September 5, 2003 Report Posted September 5, 2003 Yeah, no shit, eh? Brake cleaner is for brakes! Carb cleaner is for carbs! Use throttle body cleaner for your throttle body. BRAKE CLEANER? :shock: I was told that even carb cleaner was too harsh for a EFI TB. so, I used some TB cleaner, worked great. Quote
Redfox340 Posted September 5, 2003 Report Posted September 5, 2003 Yeah, no shit, eh? Brake cleaner is for brakes! Carb cleaner is for carbs! Use throttle body cleaner for your throttle body. You'd be amazed... Choose and read, many of them have the same solvent compound. - Erik Quote
topless94style Posted September 5, 2003 Report Posted September 5, 2003 I used carb cleaner. Worked great and not a problem. Quote
