manualy shifted auto
well If anyone remembers my auto tranny in the 93 is stuck in one gear.
I was thinking and looking at the wiring diagram and thought I'd try it.
so I crimped wires onto the wires coming out of the tranny. I have a wire for ,shift sol a, shift sol b, and a 12 volt power wire going into the inside of the car. after some testing my brother and I took it down the road and he shifted it with the wires. I can get it to go into first, second, and third gear. I can't figure out how to get 4th yet. to get 1st you add power to a and b. for second you leave them off. then for third you add power to just a. now what would make it go into fourth?( I tried power to just b but no luck)
marcus
TAP shift is awesome!!!! Explain how you are doing this a little bit better, I want to know more.
You are skipping second there. First is both on, second is one on, third both off, and fourth is opposite of second.
Just be sure you are grounding the solonoids.
you thinking about doing it on the 91? if so...your tranny is not electronic...93 was the first year the 3.1 got the 4T60-E.....91 started the 4T60-E for the DOHC motors only
well I found 2nd gear. so I can shift through all gears now.
I'm going to get two switches and use them too shift.
kinda cool being able to shift at any rpm I want.
now I just have to fix the problems with the motor and body.
then I'll drive it until I get all the parts I need for the swap.
marcus
