jake91 Posted May 12, 2009 Author Report Posted May 12, 2009 that why when i get back from illinois i am going to see if i can get rotors Quote
Night Fury Posted May 12, 2009 Report Posted May 12, 2009 Going to see if you can? Well, YOU CAN! What are they like $10 a pop? They are easy to do... Quote
jake91 Posted May 12, 2009 Author Report Posted May 12, 2009 more like $30 a pop and i have $100 to my name so i am going to try to get new rotors from midas again Quote
xtremerevolution Posted May 12, 2009 Report Posted May 12, 2009 more like $30 a pop and i have $100 to my name so i am going to try to get new rotors from midas again Bitch the hell out of midas and don't be a pussy about it. Know your facts and print out the spec sheets before you go so you have some facts to shove in their faces. If they refuse, threaten to sue on account of damaged rotors that can pose life-threatening conditions, and demand to speak to their district manager. Don't EVER take no for an answer when dealing with these idiots. Trust me on this. Just stick to your facts and don't budge. If you look like an idiot they will walk all over you like they have. That being said, R1 Concepts blank rotors are $37.40 for the pair, zinc coated, plus $16 shipping. IMO that's a lot cheaper than having them turned anywhere you can possibly take them. Quote
Regal_GS_1989 Posted May 12, 2009 Report Posted May 12, 2009 Shops like that need to know that you know your facts otherwise they will try and pull stunts. Which is why I posted the data directly from Alldata. If you show up there with a print out from a web forum, they can easily say that it is wrong, their specs are different blah blah blah. But the fact that it is from AllData, means it's from a trustworthy source, and probably the same source that Midas uses in the first place. Quote
jake91 Posted May 12, 2009 Author Report Posted May 12, 2009 i believe it is because i think i saw a sticker in the window along with the ones for the parts they use that said alldata Quote
tornado_735 Posted May 18, 2009 Report Posted May 18, 2009 The assholes at Midas changed the serpentine belt in my Jeep, and the bastard still squeals. Quote
tornado_735 Posted May 18, 2009 Report Posted May 18, 2009 they didnt replace the tensioner then Oh, I know they didn't. I actually got to thinking about it and it only squeals when you are at low idle with the AC on. Squeals like a mofo. Turn the AC off, and it goes away immediately. Turn the AC on on the road or freeway, and it'll freeze you. They're still assholes though, even if it isn't their fault. Quote
Ned Flanders Posted May 18, 2009 Report Posted May 18, 2009 Being a chick doesn't help when it comes to getting crap fixed at these chains. Merchants ripped me off once on my brakes, fool me once... My favorite was the day I really needed an oil change and what looked like a local shop was offering a 25 dollar deal. Well, they were just as interesting as Jiffy Lube and had some national tie. They keep yanking parts off my car and showing them to me. "Your air filter's dirty, this PCV valve is clogged." Now any drooling bottom feeder can replace either of those. Then they start in on me needing high mileage oil. I tried to be cool but ended up pretty bluntly saying that if they yanked one more part off my car, or tried to charge me for ANYTHING other than the 25 bucks I was going to drive right to the BBB and file a complaint about false advertising, not to mention destroying personal property by popping parts out from under the hood. I'm back to either doing it myself or taking it to my mechanic and buying the oil and filter. Jiffy Lube, Midas and Quaker State don't care if they lose a customer. Right now a local mechanic and hell, even a dealer has to worry the way things are going. Quote
tornado_735 Posted May 18, 2009 Report Posted May 18, 2009 Being a chick doesn't help when it comes to getting crap fixed at these chains. Merchants ripped me off once on my brakes, fool me once... My favorite was the day I really needed an oil change and what looked like a local shop was offering a 25 dollar deal. Well, they were just as interesting as Jiffy Lube and had some national tie. They keep yanking parts off my car and showing them to me. "Your air filter's dirty, this PCV valve is clogged." Now any drooling bottom feeder can replace either of those. Then they start in on me needing high mileage oil. I tried to be cool but ended up pretty bluntly saying that if they yanked one more part off my car, or tried to charge me for ANYTHING other than the 25 bucks I was going to drive right to the BBB and file a complaint about false advertising, not to mention destroying personal property by popping parts out from under the hood. I'm back to either doing it myself or taking it to my mechanic and buying the oil and filter. Jiffy Lube, Midas and Quaker State don't care if they lose a customer. Right now a local mechanic and hell, even a dealer has to worry the way things are going. Chaps my ass when those bastards try that shit. I do it myself anyway. I use High Mileage Oil in the GP, but I'm thinking about switching to Kendall conventional. It was on sale, so I put it in my Land Rover and it's stayed nice and clean. Quote
jake91 Posted June 8, 2009 Author Report Posted June 8, 2009 we after all this the rotors are fine pepboys lied to me also by telling me my rotors were under cut. now that im back from il i bought a caliper and mesured them and theyre fine they are 1 inch in the front and 10 mm in the rear. and before anyone says anything yes i know im an idiot Quote
digitaloutsider Posted June 9, 2009 Report Posted June 9, 2009 What are you using to measure you rotors..? You use a micrometer/caliper not a ruler. Quote
Brian P Posted June 9, 2009 Report Posted June 9, 2009 That's not bad, but that caliper is only going to measure the VERY EDGE of the rotor. Granted your rotors are freshly cut so they *should* be flat, but there's usually a lip at the edge since the pads never contact that area. The best way to measure is with a caliper that has protrusions at the tips, or a standard micrometer/vernier caliper. Kind of like this: This is a brake rotor caliper: http://www.denlorstools.com/home/dt1/page_1302_98/fowler_brake_drum_and_rotor_measure_kit_with_elect.html Quote
jake91 Posted June 9, 2009 Author Report Posted June 9, 2009 i think the rotors are pretty uniform as you said they are freshly cut, and that when i was mesuring them the caliper had pretty even grip across the whole rotor. Quote
