Installed UB3 in Lumina
Well I done did it today. I just layed the cluster in for now, and will touch it up later. So far the volts and fuel and speedo and tach are working, sorry for the blurry ass pictures.
It's installed at a similar angle in a Cutlass so it makes sense to tilt it like that.
Correct Its still in the cutlass housing, I need to borrow a dremel and fit the guts inside the lumina cluster.
Regardless of how its tilted, I think it looks great. I think you had to go through less than what I went through. I had dropped a Monte speedo cluster in the lumina and had to pull the speed needle off a second time after installed. I had to do this because it read 5mph at rest.
