HUD and DIC Question
Is there any way I can find out? RPO codes or something?
If it is indeed prewired, would the wiring harness just be sitting there with an unplugged connector?
It would likely be tucked in the harness somewhere.
If Jake comes over this weekend, I will have a look see myself.
My '93 SE was prewired for HUD, but not the DIC. I doubt the cars would be prewired for the DIC since it was a standalone harness on the C200. The connector was sitting behind the wiper pod, taped in foam.
There was also an RPO code for prewiring (atleast thats what I'd guess its for... other cars that I've seen fully optioned didn't have this RPO), "WX7: Wiring Provisions."
I pulled the dashpad off and found this connector neatly bundled together in a square of foam tucked behind the gauge cluster....
I can has HUD?!
:jumpalot: Sweeeeeeeeeeeet!
Now where are they hiding the DIC harness on these? :lol:
There won't be a DIC harness. You should be able to plug it into the C200 connector and it will be plug and play.
