SUPERCHARGER!!!!
it will fit... but..... then you need to do about $100,000 more work so you can even make the car move.
you would have to convert to OBDII, which requires the PCM from a 97 3100 car, athe engine wiring harness from a 96 3100, and you should do a top end swap to have the larger intakes, plus larger exhaust manifolds and a complete better flowing exhaust system, plus getting the tranny built to performance specs to take the power (and I would add an auxiliary transmission cooler...) and then....... getting a $500 program that you can tune the car with.... not to mention other performance mods to make the car stronger like valve springs and roller rockers...
that wouldn't be any different.
for most purposes: if it works on a 3400, it should on a 3100, that being said 3500 heads dont work on a 3100.
fuck that then lol do they make a kit for the 3100?
this kit will fit. but to make it run once on.... is what I am talking about.
You have a 1995 gp. IT HAS AN UNHACKABLE UNPROGRAMABLE PCM. (only the dealership can do it, no one has successfully done it on their own)
Without the programming, the PCM will not be capable of operating the car because it is not programmed to operate while seeing boost. to correct that, you need to upgrade the vehicle to be able to be re-programed, since the current PCM cannot be re-programmed. the Programmable PCM comes from a 97 model year car, and you must upgrade the wiring to accommodate that PCM upgrade. Plus then you must tune it.
You also need to upgrade the engine to the best flowing components to maximize the use of the super-charger (which you would be better off doing anyhow, and not getting a supercharger)
once you have done that... you will likely BLOW up your transmission the first time you go WOT, unless you get it re-built to race-specs.
simple enough? there is no easy solution.
nor does anyone seem interested in tuning our cars...
OBD 2 swap, the parts can come off a 96+ w-body
Jamie
What would happen the first time it boosted without re-programming?
it would probably stall at any point above idle. the fuel mixture would be all off.
Jamie
A 96 has a 256 computer and the 97 is 512 so the 97 would be ideal.
Jamie
Whats the difference between the two? I didn't even know there was a difference. Does this apply to LQ1 cars as well?
Jamie
Jamie
Jamie
the way it was explained to me: GM didn't know what the hell they were doing when it came to obd2, so the 96 model year vehicles all got a half-assed computer.
LoL GM and half assed? :lol:
I thought that was a given :lol:
I was hoping for something a little more specific, lol
Jamie
the writeable memory in the 96 is only 256KB
the writeable memory in the 97 is 512KB
for whatever reason, the good tuning programs need the 512KB memory... they must use all of it?
Ohhh ok, that makes more sense... granted I know squat about the programs, but I can understand that.
Jamie
no shit 512MB? wow, i thought it was KB you were talking about. no wonder it takes a while to flash a obd2 computer...
I find it pretty amazing that the computer that runs your car only has 512 MB of memory, while iPod's are out there with 160 GB hard drives. Technology is defenitely amazing, I can hardly keep up with all the advances!
i would hope... the bins running my wifes GP and soon enough, when the final plug gets here, my MC are only 32K in size... to go from needing 32K to 512MB in only 4 years... i think microsoft caused it. :lol:
wait... I meant Kilobytes. I think....
I am not sure either. Ask Bob he is big into tuning.
so i can get all the stuff to do an obd2 swap at this one junkyard in june cause there having a sale..(35$ to get in and all the parts are a dollar)...including motors http://www.wegotused.com/specials.htm
they have over 10,000 cars there...its a god like place lol
my question is why would he need obd II? They are listing it to work with Fieros. Im just not understanding why OBD II would have to be used.
