GPdriver1986 Posted August 31, 2003 Report Posted August 31, 2003 I have a normal Delco stereo in my GP and I have a few questions about the setup: 1)Where is the amp? 2)How many watts does this stereo pump out? 3)How much power can the speakers handle? 4)If I upgraded my stereo would the system sound better if I replaced my back speakers with premium speakers? Quote
sl3196 Posted August 31, 2003 Report Posted August 31, 2003 1)Where is the amp? 2)How many watts does this stereo pump out? 3)How much power can the speakers handle? 4)If I upgraded my stereo would the system sound better if I replaced my back speakers with premium speakers? I have I 96 cutlass. My amp is in the trunk behind the carpet on fender or under rear speakers. If you upgrade speakers get really good ones. I got some cheapos and they can't handle the factory amp so I can't use it. BTW I replaced the stock stereo but I used to use it. It will sound a lot better as long as you get premium speakers, no wal-mart specials. Not sure on amps but it must be above 100watts. Quote
GPdriver1986 Posted August 31, 2003 Author Report Posted August 31, 2003 Do you guys think that if I buy premium Grand Prix speakers and put them in when I get my aftermarket radio it will sound better? Quote
Brian P Posted September 1, 2003 Report Posted September 1, 2003 I have a normal Delco stereo in my GP and I have a few questions about the setup:1)Where is the amp? 2)How many watts does this stereo pump out? 3)How much power can the speakers handle? 4)If I upgraded my stereo would the system sound better if I replaced my back speakers with premium speakers? A '91 LE right? Your amp is the top piece of the stereo unit Watts are like 22rms/channel Speakers can take at least 30w rms If you keep delco with delco, then you keep the bass. If you use aftermarket speakers, you will gain hi's and clean up the mids Quote
92Cutlass4Dr Posted September 1, 2003 Report Posted September 1, 2003 I'd go aftermarket with everything. Any factory speaker, even premium, are not as good as mediocre aftermarket gear and the factory is much more expensive. As far as power goes, you don't have much in a factory deck, maybe 10 watts per channel of continuous power, aftermarket usually ranges from 18-30 in a deck. Quote
