What is the differance in 3.4l
I was wandering what the differances is the 3.4l. What I have is a 93 and the junk yards are saying that a 94 and newer 3.4l are different.
94/95s have a cam sensor and a second crank sensor, but you can use them no problem in a older car, you just won't hook either of those sensors up
96/97s in addition to having the aforementioned sensors added they also have a different exhaust setup so you will need the exhaust manifolds off the donor car as well, and maybe the crossover, but that is speculation on my behalf more then anything. but other then that they will work just fine.
did you ever look into that oil pump drive leak? I have never seen a rear main seal go out on one of these engines.
Thanks and no I haven't had a chance and if you could tell me where it is located.
Also I know the intakes are differant. But would a 93 intake work on a 94/95 motor?
yes, besides... they are the same intake. 91-95 is the same, 96-97 is different
That being said, a 96-97 intake will fit on the older engines
I have a 97 intake set up waiting to go on my 95
Jamie
Jamie
except for the work of adding or bypassing the EGR
As much as I hate giving this answer, Search. I know I have personally typed this up no less then 8 times in the past several years.
Jamie
Touché I keep forgetting about that! gonna suck when I go to do the swap and suddenly realize that I gotta figure something out last minute!
Jamie
See attached pic.
OK so I checked other threads. But I couldn't fine the one that seam to relate to the 3.4 thay all read like it was the 3.1. Is it that I can get to it by removing the intake or do you have to tear down even more?
To do it "properly", you are supposed to remove the rear head because it blocks you from pulling the drive out more than about 1/4"
I did it with the heads off as shown in the pic because I needed the valves redone anyways due to a snapped t-belt (long story), so it made sense. Most everyone else does it without pulling everything apart though, and there are many threads on that method. Since I've got no experience with the alternate methods, I really don't have any info for you other than to search again, or maybe dig through the FAQ section. I know there are threads that describe the procedure, just gotta find 'em.
OK I found the shaft on the motor and dose look like where the source of the leak is coming from. But is there a way to fix this without removing the head.
Anyone have an answer or am I removing the rear head?
I will get GOT2B GM to post, I think he fixed this without pulling the head...
Jamie
OK so back to the topic. So the engines basicly the same though out the years it is the addtion of sensors that have changed on them? The reason I asks is can you take say a 95 block and put 93 heads on it?
I think the block is the same.... here is what I think is different:
IIRC:
the timing belt housing is different to allow for the crank sensor, and front cam carrier (and it's valve cover) are different to allow for the cam sensor, and the cams have a different cog lock (something like that)
the good news... is you can stick a 94-95 engine in your 91-93, leave the unused sensors unhooked, and it will work fine as is.
Thats good news cause my 3.4 has 170,000 and I like to pick up a spare motor and start rebuilding it.
91-93: Different vacuum setup, MAP sensor, OBD 1
94-95: Cam sensor, different timing cover with the addition of a second crank sensor, simpler vacuum setup, MAF and MAP sensor, different alt (because of the timing cover change) OBD 1.5, I want to say the cams are different
96-97: OBD II Different intake, different heads and cams, different exhaust manifolds. Pretty much everything from the block up is different
As for taking a 94-95 motor and putting it into a 91-93 car: Most people run into issues wiring up the newer style alt. to the older style plug.
EDIT: For the oil pump ring. Unbolt it and take a dremel and notch the top of it some so you can lift it up. Clean the area. Most people try to get a distributor o-ring for a chevy SBC, then coat the area in RTV.
I just coated it in RTV, doesn't seemed to have leaked since then.
not an SBC, get one from a 1978 chevy with a v6. the sbc are too large, IIRC.
but to get a solid size comparison at the parts store, the "proper" O-ring outer diameter must be about the same as the inner diameter of the paper gasket you must buy for a 78 chevy V6... but no more than 1/4 of an inch too large.
