i new here my name is jon. now down to bussiness can i swap a 1991 z34's gauge cluster with a 2 door lumina coupe same year i want to trasfer mine into a z34 look a like. second can some opne tell me the difference between the rear suspension on a z34 and a basic 2 door coupe pics will be nice.
Hi. Well first off you'd have been better off posting this in a new topic since more people will see it. Also, it is better to post each question in its respective section (there is a brakes/steering section) but your questions are easy for right now:
The rear suspension on the Z34 will have the bigger rear sway bar, along with the stiffer "sport" spring. The base Lumina coupe may have either a smaller swaybar, or no swaybar at all, along with a softer spring. If there is no swaybar, you may have the "auxiliary springs" near each wheel that the Z34 may not use. The swaybar can be installed, however if your car originally didn't come with one, you're going to need to buy body hardware at the dealer (mainly the nut inserts which install into the frame) as well as all brackets from the donor car.
Someone else will have to answer the gauge cluster question.
